Clutch problem(s)
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. So i have the 80cc chinese motor, have had it for a few months now. I also have the clutch ...
Old 04-03-2009, 06:52 PM
Default Clutch problem(s)
So i have the 80cc chinese motor, have had it for a few months now. I also have the clutch actuator kit from jim at creative engineering. It works good and everything but the other day i changed the clutch pads because the clutch started slipping a bit. And now when i tried to adjust it , the clutch isnt grabbing hard enough and i can feel it slipping when i have the clutch engaged. But when i disengage the clutch i can hear the clutch grabbing a little bit still. This doesnt change no matter how i adjust it. Ive spent at least a couple hours on it trying to figure it out but nothing works. Still the same results no matter what i do. its almost like the pressure plate or whatever you want to call it is too smooth and it doesnt grab very well. Anyone have any kind of an idea?
Old 04-03-2009, 07:13 PM
commander's Avatar
Default Re: Clutch problem(s)
I made the mistake of greasing the gears in there once and I had similar results you are having. If you recently did this then use some brake clean and remove all grease from your clutch area and reassemble and give that a try .hope this helps
Old 04-03-2009, 07:25 PM
Nope i never greased the gears at all. Its all clean in there. The presure plate is super smooth though. Still has the holes in it but its super smooth.
Old 04-03-2009, 07:38 PM
commander's Avatar
this is kinda a no brainer, but did you tighten the clutch plate enough to make it grab the pads when engaged ? I know that happened to me also after I disassembled one to see how it worked
Old 04-03-2009, 07:44 PM
Yeah i did but no matter how much i tighten it. It just doesnt work. I dont know maybe im stupid and im just forgetting something.
Old 04-03-2009, 07:47 PM
commander's Avatar
sorry Qdot, I guess i cant help ya much . try to do a search here in the forums and see if there is a tutorial on clutches
Old 04-03-2009, 07:51 PM
Maybe ill just tighten the piss out of it and see what happens.
Old 04-03-2009, 09:05 PM
Tightened it up and still same deal. I have no idea.
  #9 (permalink)
Old 04-03-2009, 10:06 PM
Bikeguy Joe's Avatar
External adjustment of the primary clutch spring
  #10 (permalink)
Old 04-03-2009, 10:54 PM
Creative Engineering's Avatar
MANIC Mechanic
Qdot,
As Joe pointed out, I did a post on the external adjustment of the main clutch spring. At the time I didn't have a decent camera...I do now, or at least a better one. I also didn't have the entire engine in my CAD system, now I do.
Let me know if you're still having trouble and I'll try to get some better pictures tomorrow. This combined with the CAD renderings should clear this up.
In the post I was offering a solution to a really tight clutch. If the spring were set too loose it will also cause the clutch to slip no matter how much you tighten the star nut.
I'm working on getting all of this stuff up on my website for everyone to use...It's time consuming.
Jim
