Clutch problem
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I have had far too many problems, but my current one is a clutch problem. the clutch arm is pointed ...
Old 09-28-2009, 09:51 PM
Default Clutch problem
I have had far too many problems, but my current one is a clutch problem. the clutch arm is pointed to the back right before I run into any resistance. If I try to activate it by pushing it towards the engine even all the way, I cannot disengage the engine. PLEASE HELP, if it didn't cost so mch to ship it I would honestly just give it to Spooky Tooth to get the bike done, I have just about had it after 4months of problems
Old 09-29-2009, 12:59 AM
Default Re: Clutch problem
hey trust me...its probably gonna be fine...when the clutch is engaged the arm points straight back...set the cable to be at full extension in this position...the clutch disengages when the arm is pulled over the top of the motor...right now you are swinging that clutch arm around and there is no resistance...what you think is the end of the throw is actually where you will start getting spring tension....by the way its allot of spring tension....just keep building....trust me the clutch is fine
Old 09-29-2009, 12:57 PM
wes wes is offline
Ive had this problem, it was on a motor with 6-7000 miles on it and around 4500 or so the ball bearing was warn in side where the rod passes through the engine, this is behind the casing on the lever side, ive also had this problem when the clutch pads were warn out and i adjusted the flower nut to tight after replacing, if this is a new motor and the clutch worked fine before than i would listen to Noco, its probly an easy fix with the cable adjustment, good luck!!!
Old 09-29-2009, 03:19 PM
Hot Wheels's Avatar
Make sure the ball bearing is still behind the pin that the clutch arm pushes on.
Old 09-29-2009, 03:42 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I concur! check the ball bearing & the little rod inside the clutch shaft.
If you need to, you can make a slightly longer rod from a old screw driver shaft.
Old 09-29-2009, 11:31 PM
thanks guys, I'll try it as soon as I get time. Also if anyone is in the seattle area with an eligible multispeed frame fo cheap, I'm lookin for one since the '73 Schwinn 'Burban is just not workin (as soon as I got everything attached of course, haven't even fired it once)
Old 09-30-2009, 01:43 AM
dude that bike is a stallion...what you looking to do...for hanging around town that single speed is perfect
Old 09-30-2009, 07:16 PM
da, the bike is epic lookin, and cause it's a 10 speed I can ride it on our hills around some local police that are notorious for fishin'. But the chainstays are to narrow and I can't fit the sprocket and chain in line, and bending 36 year old steel may be possible but with assorted washed out roads and a school parking lot made out of pothole patches it's pretty dumb, I'll see about sellin it if I find another eligible bike for my motor.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/clutch-problem-11609.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 09-29-2009 10:18 AM
