Clutch actuator upgrade
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Does anybody have for sell or know where I might find an after-market (reduced effort) clutch actuator that will ...
Old 11-09-2009, 08:59 PM
Question Clutch actuator upgrade
Does anybody have for sell or know where I might find an after-market (reduced effort) clutch actuator that will fit a Raw Motors 80cc engine. Manic Mechanic did at one time but discontinued for some reason.
Old 11-09-2009, 09:12 PM
Default Re: Clutch actuator upgrade
Rock Solid has some
Old 11-09-2009, 09:58 PM
2door's Avatar
Chucky,
There is a modification that you can easily do with your stock actuator that will reduce the effort needed to activate, (disengage) your clutch. You'll need access to a Dremel Tool, bench grinder with a buffing wheel and a few minutes of your time. I should really do a photo tutorial on this but I haven't had the time. Nevertheless here is a brief look at the project.
The parts that need attention are the clutch actuator cam, the part the clutch lever attaches to, and the pin which the cam presses against. From the factory these parts are very rough and there is considerable friction between them. Even when well lubricated the rough surfaces increase the effort of clutch actuation.
Remove the clutch actuator cover and then remove the cam from it by rotating it about 90 degrees and pulling it out of the housing. Remove the pin from the center of the engine drive sprocket. Using a Dremel, or other high speed grinding tool that will accept a sanding disc, carefully smooth the surfaces of the cam and the end of the pin. There's no need to get too aggressive and don't remove a lot of material. Just smooth the contacting surfaces and round off any sharp edges. This much will help but if you have a buffing wheel and some compound, polish the surfaces you smoothed with the sanding disc until they look like chrome. Clean and lubricate the cam and pin and reassemble. I think you'll be pleased with the results of your labor. In addition to this work you might want to lubricate the clutch cable and make sure there are no sharp bends or kinks in its length. Let us know how this works for you.
Over Youth and Skill
Old 11-09-2009, 10:07 PM
Thanks for the info, I will give it a try.
Chuck
Old 11-09-2009, 10:20 PM
misteright1_99's Avatar
I added a short piece of copper on to my stock arm, and swiveled it inward on the splines. It makes the pull much easier.
Old 11-09-2009, 10:32 PM
Creative Engineering's Avatar
MANIC Mechanic
And this is the very reason why I won't be making any more. The product I manufactured, (clutch actuator kit), made the clutch "sweet" to operate...
No offense Tom...none at all!!! Your input is always respected.
The forums are full of advice on how to make the clutch easier to pull. The truth is...the design is bad. No matter what you do...your clutch lever pull effort/clutch feel...will never equal the effect that my clutch kit offered.
Those that have it...love it!
Jim
Old 11-11-2009, 01:25 AM
DVBikes's Avatar
i cut copper pipe circles 1mm and put them with the pin inside works great doesent look ghetto
Old 11-11-2009, 02:10 AM
flybytaco's Avatar
get one from jim!!! forget about hack tricks bolt on some billet keep jim in buisness
couldnt build my bikes without PIRATE CYCLES and billet from CREATIVE!!!!! THANKS JUSTIN!!
  #9 (permalink)
Old 11-11-2009, 02:13 AM
flybytaco's Avatar
Originally Posted by flybytaco View Post
hey how much for one send it to justin if you have one thanks
rick
and how about the hub adaptor for the 7 speed swins need 1 too
  #10 (permalink)
Old 11-11-2009, 02:38 PM
2door's Avatar
In some cases, "hack tricks" are all a person can afford. For others doing it themselves and finding solutions to problems is more satisfying than writing a check. Jim makes a good product but its not the only route available.
