| Sponsors
| | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Chain Tensioner/Guide Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello All. I finally purchased the bike engine kit and have it installed. What a fun project. I got to ...  | |
06-25-2008, 05:36 PM
|  | Motorized Bicycle Apprentice | | Join Date: Jun 2008 Location: Chico, CA
| | Chain Tensioner/Guide Hello All. I finally purchased the bike engine kit and have it installed. What a fun project. I got to ride my new motorized bike for about 8 miles before the chain tensioner/guide screw was stripped and useless. Now, I have to find a replacement or better solution. In browsing some of the forums, I see a lot of mods and interesting work around for this. I have been to every hardware store and bike shop in town and cannot find anything that will do.
Any suggestions
1) Buy another crap replacement chinese part?
2) One bike shop offered a guide that is used for tandem bikes. It looks like it "could" work, but the teeth are not too deep. Also, it does not have a groove like the part that came with the kit. I saw one post with someone that had soemthing similar. Could this work?
3) I have been referred to a metal fabricator to try and provide the stripped bolt that holds the plastic tensioner/guide in place.
I appreciate any advice or suggestions you have. I appreciate your help. |
06-25-2008, 05:49 PM
| | Re: Chain Tensioner/Guide Have you tried to press out the bolt that is stripped from the roller? It should come out with light whack.
How about replacing the roller assembly with a bolt and a skateboard wheel?
06-25-2008, 05:51 PM
| | Re: Chain Tensioner/Guide Yes, I got the bolt out, it was stripped. That bolt is a proprietary piece that holds it on, but allows it to spin. The local motorcycle shop had a piece that would be similar to the skateboard wheel, but there is no guide on there. How important is the "guide" aspect of the groove in this piece? |
06-25-2008, 05:56 PM
| | Re: Chain Tensioner/Guide It's (the groove) not, the chain just runs across the roller, it's not really a guide, but more a way of facilitating chain adjustment on a wheel that already has one chain on it.
Don't get the chain too tight. 3/4"-1" of play will do it.
| | Re: Chain Tensioner/Guide I drilled out my center bolt( used a metal lathe) that mounts the chain roller and inserted a usa(american) bolt in its place that I can reef on and not strip I think the bolt is a 5/16" dia
I have a post on this forum showing what I did as well but then again I'm not the best at using the search but if you look for them that I posted you will run into it someday.  |
06-25-2008, 06:01 PM
| | Re: Chain Tensioner/Guide If it were me, and if it is a coaster brake type bike. I would set the bike rear wheel for the motor chain without the tensioner, then put the tensioner on the bike chain with just a bolt and nut to hold the wheel in place. Since the bike chain will get very little use ,all it will do is keep it tight. It won't need to spin. |
06-25-2008, 06:24 PM
| | Re: Chain Tensioner/Guide My sprocket for the engine is on the opposite side of the 7 speed pedal power sprockets. Pedal is on the right and engine sprocket on the left - looking from the rear. |
06-25-2008, 06:29 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
06-25-2008, 07:03 PM
| | Re: Chain Tensioner/Guide There ya' go.
06-26-2008, 01:10 PM
| | Re: Chain Tensioner/Guide Thanks. I ordered these parts from TSC and they should arrive next week. Thanks for the advice. You guys are great. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:41 AM. | | |
