Motorized Bicycle General DiscussionTopics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles
chain tensioner
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. i was fiddling with some stuff on my bike and 5 miles down the road my idler pulley came off... ...
i was fiddling with some stuff on my bike and 5 miles down the road my idler pulley came off... ididnt tighten it down enough. where can iget a new pulley
I really like the one that ThatsDax sells. I replaced the one that came with my kit with theirs. It has a ball bearing in it that made things run smoother for me. Some other people remove the tensioner altogether.
I'm pretty fond of the skateboard wheel too I thin them on the lathe and cut off the outer rubber or what ever that stuff is then make a little shoulder on each side seems to work very good.
Norman
I grind the groove the old fashioned (or hard) way- on a bench grinder.
Hey Norman- I never knew there was an "outer tire" on those things and I was grinding the groove into my first one and the "re-tread" flew off like a road gator from a 100mph semi!
__________________ If it ain't broke, and you mess with it long enough, it will be.
