chain tension help
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. is their someway to make the chain tighter like a single link available? i am using the chain tensioner but ...
Old 01-12-2008, 11:04 AM
CRUISER's Avatar
ADMINISTRATOR
Default chain tension help
is their someway to make the chain tighter like a single link available? i am using the chain tensioner but have to have it all the way up for it to keep the chain snug. i tried to remove another link but then it was to short by just a pinch. my thoughts are the straighter the line from the sprocket to the engine the better it will be.
http://stockmarketcats.com/
Old 01-13-2008, 07:45 AM
RedB66's Avatar
Default Re: chain tension help
Cruiser, one thing you may try is to add a master link to the regular bicycle chain which will allow you to move the wheel back, allowing you some adjustment on the motor chain. Also you can try to adjust the location of the tensioner, closer to back wheel or closer to the motor. I had the same problem on my chain.
Old 01-13-2008, 08:25 AM
CRUISER's Avatar
ADMINISTRATOR
thanks red. my drops go straight down and i thought of that also, i have the tensioner as close as i can get it to the sprocket already. i will keep messing with it though. i think the only alternative is to remount the engine which i really do not want to do
Old 01-13-2008, 09:13 AM
Motor Bicycle Apprentice
You might consider using a half link.
Old 01-13-2008, 09:19 AM
CRUISER's Avatar
ADMINISTRATOR
where would i get a half link pete? that would solve all my problems. i looked on ebay and they had for size 10 and 40 i but could find nothing for a 415
Old 01-13-2008, 09:32 AM
CRUISER's Avatar
ADMINISTRATOR
found one. here is a link and i will let you all know how it works. this enternet sure is great for finding stuff. https://www.albes.com/index.asp?Page...OD&ProdID=1304
Old 01-13-2008, 02:23 PM
Andyinchville1's Avatar
Manufacturer/Dealer
Sometimes it helps to slide the entire chain tensioner assembly rearward (closer to the rear sprocket) often times this will take care of minor chain tension issues without the need for
messing with the links.....since the stays typically taper towards the rear axle, sometimes I the brackets may need minor "adjusting"....Helps to have a large pipe wrech, vise, and/or large hammer....just be careful if you have to "tweak" things.
Andrew
Old 01-13-2008, 02:28 PM
Manufacturer/Dealer
OOPs....just noticed you already said the tensioner was as far back as possible...Hmmm...
Oh....actually, seems like you could add another link or two and just lower the tensioner
guide wheel Possibly in conjunction with moving the tensioner forward or backward)?....You seem to be too close for it not to work.....Maybe a pic would be helpful?
Andrew
  #9 (permalink)
Old 01-13-2008, 03:11 PM
CRUISER's Avatar
ADMINISTRATOR
here you go. i think a straighter line from the tensioner to the motor would make a lot of diference in the performance. maybe i am wrong but would like to see
  #10 (permalink)
Old 01-13-2008, 05:29 PM
Bikeguy Joe's Avatar
Genius Visionary
Move the tensioner forward and remove a link from the chain.
Advertisers
