here it is all back on and you can see at the top limit. Note the sheet metal screw and socket head bolt these are to stop the bracket from rotating into the spokes . The socket head bolt hole is tapped in the frame and drilled a hair over size on the bracket. I also have shims under the bracket as the frame dia. wasn't large enough and the bracket wallered around on the frame.
