chain tension help
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. i am not using a tensioner i just made my chain one link shorter then added the half link works ...
  #21 (permalink)
Old 01-20-2008, 02:08 AM
Motorized Bicycle Builder
Default Re: chain tension help
i am not using a tensioner i just made my chain one link shorter then added the half link works great
  #22 (permalink)
Old 01-20-2008, 02:24 AM
MotorbikeMike's Avatar
Dealer
Hi Wayde, it's been my experiance that half-links are weak and problematic. This is wht I developed the "T-Shirt".
Tine will tell on your bike, but I've had half-links fail even on the people chain, so I will never trust one on an engine again.
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
  #23 (permalink)
Old 01-20-2008, 02:28 AM
time will tell i guess i've either been lucky or i found a good one i'm doin about 52 km/h and it's a blast
  #24 (permalink)
Old 01-20-2008, 06:58 AM
deacon's Avatar
I took a few links out of my motor chain and then used the tensioner on the people chain. The tensioner doesn't get much use so should last forever. Seems to work fine after I got the tension on the motor chain about right.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
  #25 (permalink)
Old 01-20-2008, 10:13 AM
Pablo's Avatar
All I can say is tensioning the chain is the biggest headache so far.....I don't mind taking links out (kinda fun really) but it just seems like I can't get the tension just right and the tensioner seems to interfere more than it helps. Also it seems like my sprocket has a small side to side wobble (NOT up and down alignment). Maybe one side is tighter than the other......
  #26 (permalink)
Old 01-20-2008, 10:19 AM
deacon's Avatar
On mine which I probably did wrong. I measured the distance from the sprocket to the first spoke one both sides of the nut. i tightened the nuts till the distance was the same for all of them. Not sure if that would help. but yeah it was a pain for me and i am never sure I have it right.
  #27 (permalink)
Old 01-20-2008, 10:26 AM
Andyinchville1's Avatar
Manufacturer/Dealer
Short of mounting the sprocket on a grubee hub or mounting a custom(ized) sprocket to the disc brake hub it is very difficult or nearly impossible to have a perfectly mounted sprocket with no side to side or up an down wobble....You can get very close tho or at least close enough..
Andrew
  #28 (permalink)
Old 01-20-2008, 11:32 AM
Pablo's Avatar
Originally Posted by deacon View Post
...... I measured the distance from the sprocket to the first spoke one both sides of the nut. i tightened the nuts till the distance was the same for all of them. Not sure if that would help.........
Actually that is a good idea!! Don't know why I didn't think of measuring it other than lack of O2 to the brain
  #29 (permalink)
Old 01-20-2008, 12:08 PM
i used the tensioner when i startes but the speed i went it started to melt the little plastic wheel thingy and it cooled and seized
  #30 (permalink)
Old 01-21-2008, 12:06 PM
Norman's Avatar
LORD VADER Moderator
guys here's a few pictures of chain tension first is my chain slack/at rest.
Advertisers
