| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | chain keeps hitting tire Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by SeattleMike
Any other way to keep the chain from hitting the tire besides getting a narrower tire, ...  | |
04-08-2008, 05:26 AM
| | Re: chain keeps hitting tire Quote:
Originally Posted by SeattleMike Any other way to keep the chain from hitting the tire besides getting a narrower tire, or with the tensioner? I don't want to go any narrower with the tire than it is now, and the chain keeps hitting the knobs on my tire. Sometimes when I ride it jerks kind of violently. Also, my frame is kind of damaged so using a tensioner in that spot isn't an option. My sprocket isn't concaved, and my wheel cannot be pulled more to one side or the brakes will not work. |
Get a pack of single sided razor blades and cut off the knobs on that side. It takes about 20 minutes.
04-08-2008, 05:28 AM
Originally Posted by SeattleMike My sprocket isn't concaved, and my wheel cannot be pulled more to one side or the brakes will not work. |
I wouldn't pull the wheel to one side in any amount with the spokes.
04-08-2008, 08:13 AM
| | Re: chain keeps hitting tire Me either Joe my experience with wheels pulled to the side is they wobble. Of course I never did it intentionally so I'm no expert. Mine just got they way by accident. |
04-08-2008, 08:21 AM
|  | Senior Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Seattle, WA
| | Re: chain keeps hitting tire I think I'm going to try and cut the knobs off, but I like the knobs. Is there another way? has anybody made some kind of a 'tire guard' thing, that blocks the chain from hitting the tire?
I have the kind of tire that is smooth in the middle for road efficiency, but it has knobs on the side for a bit better traction on the grass and stuff, so the knobs are useful- here is a pic: Rear Tire
04-08-2008, 08:32 AM
Originally Posted by SeattleMike I think I'm going to try and cut the knobs off, but I like the knobs. Is there another way? has anybody made some kind of a 'tire guard' thing, that blocks the chain from hitting the tire? | I got lucky - mine barely hit the knobs for a couple rotation and done.
Suggestion:
I would space the rear sprocket away using a set of matched washers. How much interference are you having?
Just go to the hardware store and get 9 washers....(take rear wheel off) loosen the sprocket bolts - and I'm thinking NO NEED to take the sprocket all the way off if it's loosened - then one at a time take a bolt out and put a washer between back of sprocket and outside donut.
I haven't done this - am I making sense? |
04-08-2008, 09:34 AM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: So.In.
| | Re: chain keeps hitting tire OK, maybe dishing the tire has some drawbacks but if your tire is not true I would make adjustments away from sprocket.As far as spacing the sprocket out some people use another nine hole rubber mount thingy . that is two of them between spokes and sprocket.Not sure if you can get them separately.Ron |
04-08-2008, 05:40 PM
| | Re: chain keeps hitting tire Just make sure the chain run is true.
How about cutting just enough from each knob?
04-08-2008, 06:38 PM
| | Re: chain keeps hitting tire I found out that the knobby tires on pavement will make you dump your bike on hard cornering don't ask how I know. But you plan to ride off road so in your case they will help if they are not hitting too bad I'd keep on riding it and let them wear off or else cut them down a little if they are interfering a bunch.
Norman
04-08-2008, 07:09 PM
| | Re: chain keeps hitting tire "Just make sure the chain run is true."
What does this mean? |
04-08-2008, 07:37 PM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
Originally Posted by SeattleMike "Just make sure the chain run is true."
What does this mean? | You want to make sure that your engine sprocket is in line with your drive sprocket, keeping the chainline straight. I use a steel rod laid accross both sprockets after the rear wheel and motor are in place. If they aren't in line you will be more apt to throw your chain. On one of my bikes I have some wheel rub, now I'm sure this will raise some flags, but I let it rub and it cut its own uniform grooves into the tire and now it runs great...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:18 AM. | | | Sponsors
