Chain Breaker
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. ok im almost done with my project....the las thing i need to do is get the chain fitted right..........
Old 10-24-2009, 05:19 PM
Default Chain Breaker
ok im almost done with my project....the las thing i need to do is get the chain fitted right.......well and get gas but w/e.....i need to know where i should get a chain breaker from that will work on the 415 chain.....will the park tool ct-5 work?????..what site should i get it from?????? thanks i really want to ride but i can't until i get this done....
Old 10-24-2009, 05:25 PM
Default Re: Chain Breaker
You don't need a chain breaker. I just use a small socket slightly larger than the pin to set the chain on, then pound the pin until it's flush with the chain and use a punch to knock it the rest of the way out.
Old 10-24-2009, 05:28 PM
2door's Avatar
Lilffihn,
Not all of us use a chain breaker. Some, like me, grind the ends of the pins flush with the cheek plate then punch the pins out, some simply punch without grinding. Either way works eliminating the need for a tool. Remember that with a roller chain you'll need to remove two links to get the master link to work. It requires two rollers on the ends of the chain. Hope this helps get you on the road. Now go get some gas, mix it at 20:1 and ride. Get back to us with the results, and pictures. Ride careful and have fun.
Over Youth and Skill
Old 10-24-2009, 05:31 PM
k but i dont have a grinder so i could just take like a nail and just pound the out of it?
Old 10-24-2009, 05:33 PM
Cabinfever1977's Avatar
walmart has a chain breaker for $5.
Old 10-24-2009, 05:41 PM
nail, hammer and some muscle work is good enough...
"Burn after reading"
Old 10-24-2009, 06:22 PM
k thanks but how can i get the chain on right now i cant seem to be able to turn the sprocket easily enough to figure out how long it needs to be...
Old 10-24-2009, 06:26 PM
silverbear's Avatar
I think I'd at least invest in a punch. A nail will bend pretty easily, which can be frustrating. I've used a nail set when I couldn't fine the punch.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
  #9 (permalink)
Old 10-24-2009, 06:48 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I assume you're talking about the small engine sprocket? Pull the clutch lever, & use a flat tip screwdriver to turn the sprocket & feed the chain through!
  #10 (permalink)
Old 10-24-2009, 07:02 PM
silverbear's Avatar
Also it will turn more easily if you first remove the spark plug. Most kits come with a tooldfor turning that. It looks like a spark plug socket. Or if you have a socket set, find one that fits. Turn the sprocket as you feed the chain in.
SB
