| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Chain Binding Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I just got a Chinese 2stroke engine kit. fitting the kit was a breeze but mounting the chain has been ...  | |
04-14-2008, 01:35 AM
| | Motorized Bicycle Apprentice | | Join Date: Apr 2008
| | Chain Binding I just got a Chinese 2stroke engine kit. fitting the kit was a breeze but mounting the chain has been a real nightmare. my chain is not sitting on the teeth very well and the teeth just push the chain to derail. I am thinking of grinding the teeth. does any one know of a solution. any suggestions thanks |
04-14-2008, 02:08 AM
|  | Senior Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Seattle, WA
| | Re: Chain Binding Pretty much everyone has to file/dremel the teeth of the rear sprocket so that they are more pointy. I think it is almost guaranteed that without doing this, the chain will pop off.
When I first got my bike going the chain popped off every minute, and the chain bunched up in the front sprocket area, and it was a real pain. Once I filed the sprocket teeth, no more problems with this.
04-14-2008, 02:25 AM
| | Re: Chain Binding it seems to sit fine on the rear but the front is where the problems are. It seams tight to get the file in to the front sprocket is it possible to remove the front sprocket and go from there with a file? |
04-14-2008, 02:54 AM
| | Re: Chain Binding Hmm, if the chain is being pushed off the teeth of the front sprocket it could be that your chain is not tight enough. These chains need to be pretty darn tight, I read somewhere that the chain should only move up and down 1/4 inch.
I'm not sure how to get the front sprocket off, I'm sure there are lots of people on this forum that can help you; its full of helpful people that know the bike kits inside and out. |
04-14-2008, 04:41 AM
| | Re: Chain Binding I think a combination of teeth reshaping and chain tension will be the way to go for my problem. I have a RK 415h chain that I will take the master link out and cut to the correct length. This chain is allot nicer than the stock chain. |
04-14-2008, 04:47 AM
| | Re: Chain Binding Adjust your chain length first, but yes some people do have to file the front sprocket. I didn't so i don't now how to do it but there will be others who answer and do know how.
Try this thread it looks to be your problem.... drive sprocket
04-14-2008, 07:14 AM
| | Re: Chain Binding Does the chain really fit well? My chain stretches so much I've been wondering if there was another chain out there the same size that wouldn't stretch. |
04-14-2008, 07:18 AM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Chain Binding Quote:
Originally Posted by SeattleMike Hmm, if the chain is being pushed off the teeth of the front sprocket it could be that your chain is not tight enough. These chains need to be pretty darn tight, I read somewhere that the chain should only move up and down 1/4 inch.
I'm not sure how to get the front sprocket off, I'm sure there are lots of people on this forum that can help you; its full of helpful people that know the bike kits inside and out. | 3/4" not 1/4".
These chains should be run fairly LOOSE or you will encounter all kinds of bearing and tensioner problems.
| | Re: Chain Binding maybe this has been my problem! dang |
04-14-2008, 07:22 AM
| | Re: Chain Binding Some have to file the front sprocket, depending on who you bought your kit from.
The chain will stretch for quite a long time, but once it's done, it will not need to be adjusted frequently. 300 miles or so should do it, until then you will have to adjust the chain very often.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:15 AM. | | |
