CARBS...I give up
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Problem: Will not Idle I have been reading in this forum about Idling problems. My MB just wont Idle!! I ...
Old 11-03-2009, 07:44 PM
Kevron99's Avatar
Default CARBS...I give up
I have been reading in this forum about Idling problems. My MB just wont Idle!! I done everything and I think I am giving up and now consider to buy a new carbs.
Here is what I already did and seem cant find a fix.
1.) Made sure that the slide and the needle is in place and the trottle springs back
2.) Apply silicon sealer on the intake gasket and the head. Applied silicon sealer between the intake and the carbs. DId all to make sure theres no leak
3.) Open the carbs and checked the jets and the internal parts for any defects or abnormality.(did not find any)
4.) Lowered the need slide one notch down
5.) Tried running on tight idler screw and tried turning 3 to 4 turns (loosen)
5.) Checked cables and made sure is free of any obstruction and kimks. Also lubricate
6.) Punch small hole on gas tank
7.) Gasoline is on 20:1 ratio (still on a break in period)
8.) Research the forum extensively - reading threads about carbs for 3 days.
Is there anything else I should do? Any suggestions? Thanks for any help.
Old 11-03-2009, 07:50 PM
Default Re: CARBS...I give up
Keep the idler screw turned in..don't loosen..keep it in.
Old 11-03-2009, 08:07 PM
Kevron99's Avatar
I have tried with the idler screw all tight up... and still wont idle. When I stop and disengage the clutch the motor just stop...
Old 11-03-2009, 08:33 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Maybe try running 24:1, a NGK B5HS plug, & replace the wire & boot with high quality replacements?
The way magnitos work is, the faster they spin; the more powerful the spark!! (slower, the weaker)
My theory here is that maybe the plug is fouling a little @ idle, & that maybe replacing the ignition parts & running less oil will make the idle stronger?
Also, get rid of the plug-ins & solder & heat shrink the wires!!!
Old 11-03-2009, 09:09 PM
Kevron99's Avatar
Ok I just got back from a test run after I uninstall and checked the carbs again and to make sure that the throttle screw is lifting the slide.
After the test drive, and when I stop, slightly disengage the clutch or press the clutch lever at 50% the bike idles but revving very high in full RPM, I tried to loosen the idler screw while the clutch is at 50% and the revving brings down a little bit, now it idles but RPM is still high. When I disengage the clutch at 100% the motor stops....its a real bummer. Any help from the forum is much needed...Thanks
My next is to try Venice suggestions...Replace the plug and plug wre
Old 11-03-2009, 09:13 PM
SOLDER THE WIRES!!! (that one's kind of important! sometimes the tension from pulling the clutch cable can 'jiggle' the plug ins & cause the engine to shut off!!)
I had that same problem on one of my builds... the engine ran great, but when I pulled the clutch, the engine instantly shut off!!! That's why I now solder all the wires on my builds!!!
Old 11-03-2009, 09:35 PM
bairdco's Avatar
get some carb cleaner and spray it all around the intake and where the carb mounts. you might have a bad casting in the manifold with a pinhole leak. if you have to keep it throttled to run, keep it at the minimum, like where it should idle. if there's a leak, it'll sputter and die when the carb cleaner hits it.
also, this may sound totally stupid, but make sure your choke isn't stuck on.
the factory setting on the idle screw is 3-4 turns out. try loosening it a little more.
Old 11-03-2009, 10:24 PM
Kevlarr's Avatar
Wait, when you disengage the clutch at 100% the engine dies? You mean you're letting out the clutch with the throttle wide open at a stop?
  #9 (permalink)
Old 11-04-2009, 12:08 AM
No... pulling the clutch lever made it die!
  #10 (permalink)
Old 11-04-2009, 12:59 AM
Kev be patient my friend. Lets explore a carb for a minute...... its extremely important that your bowl to be filled with fuel when it needs it . Your fuel is regulated in the bowl by your float and your needle valve. Your idle circuit is differant from your regulated circuit......Kev knows this.....these chinese carbs are a different creature than what im used to.
