| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | CARBS...I give up Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. here's another goofy question...
is your clutch arm hitting your carb? i've seen that before. you might be ...  | |
11-04-2009, 03:39 PM
| | Re: CARBS...I give up here's another goofy question...
is your clutch arm hitting your carb? i've seen that before. you might be shifting your carb when you pull in the clutch, enough to make an air leak.
i don't think the wires, the magneto, the cdi, or your connections are related to your problem if the bike runs, and revs, but just won't idle, it's almost certainly gotta be fuel related, not electrical.
be careful how much stuff you start messing with, or you'll compound the problem. eliminate one thing at a time till you find it.
and i thought the same about my plug wire, but it really does unscrew. you wouldn't know by looking, but it does. |
11-04-2009, 03:55 PM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2009 Location: Oshawa Ont CA
| | Re: CARBS...I give up Good to know thanks. |
11-04-2009, 04:36 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2009 Location: chicago
| | Re: CARBS...I give up Are You Running Any Lights Off The Motor? I've Found That To Many Lights Will Make It Hard To Idel, Or Not Even Start. |
11-04-2009, 04:45 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: Howell, New Jersey
| | Re: CARBS...I give up Quote:
Originally Posted by Hot Wheels Are You Running Any Lights Off The Motor? I've Found That To Many Lights Will Make It Hard To Idel, Or Not Even Start. |
No lights at all... |
11-04-2009, 04:53 PM
Originally Posted by marts1 Had a look at my spark plug wire the other day and it definitly does not unscrew at the black box on mine.So you say that when you pull the clutch lever halfway it starts reving higher which can make sense but you say when you pull it all the way in it stalls..I'd have to see that to believe it. | It is unreasonably insane to start a thread on a make believe or a made up problem! I have been looking for solution on this issue for 5 days research all over the forum before I open up this thread.
Yes on a dead stop when I pull the clutch lever at half way it does rev at full RPM and when I pull it all the way the engine stalls. I wish I can get a video of it for you to believe. |
11-04-2009, 04:56 PM
and i thought the same about my plug wire, but it really does unscrew. you wouldn't know by looking, but it does. | No Sir...the clutch arm is not hitting the carbs. I will try to unscrew the plug wires now...Anyways what is the best plug wire and booth that I can order online. Thanks |
11-04-2009, 06:45 PM
| | Motorized Bicycle Senior Member | | Join Date: Aug 2009 Location: pa
| | Re: CARBS...I give up Check the post where the clutch cable attaches to the motor.
It may need screwed in more.
Seems to leak if it is screwed out too far.
Mine had idling issue and thats what fixed it. |
11-04-2009, 07:03 PM
| | Re: CARBS...I give up Is the clutch cable binding or pulling the throttle cable?
11-04-2009, 08:11 PM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2009 Location: Texas
| | Re: CARBS...I give up I think he's got the clutch cable running into the carb...if you twist the throdle does the engine disengage? |
11-04-2009, 08:25 PM
Originally Posted by george_n_texas I think he's got the clutch cable running into the carb...if you twist the throdle does the engine disengage? | No Sir...the clutch cable is not running or binding with the throttle. I do not know the question about twisting the throttle. This issue is about idle..what I know you should not twist the throttle if you want to idle. It should be in the un twisted position...correct?
See the pics below..Thanks | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 01:04 AM. | | | Sponsors
