FAQ
Members List
Calendar
Mark Forums Read
Spookytoothcycles.com Bicycles, motors, and accesories
Pablo's Lubricants
ThatsDax.Com HOME OF THE TITAN XC 50CC 4 STROKE
Shifting Kits For Motorized Bicycles & More
80CC & 50CC
ENGINE KITS
ON SALE NOW!
Motorized Bicycle
Motorized Bicycle General Discussion
Bicycle sprocket + 415 chain?
User Name
Remember Me?
Password
Topics on
bicycle engine kits
, help articles, repair and modifications for your
motorized bicycles
Discussion at
Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion
forum. Hi I found a cheap bicycle 36t sprocket Is it safe to run a bicycle sprocket with a 415 chain? ...
LinkBack
permalink
10-12-2008, 05:41 PM
velardejose
Hi
Asuming it is properly aligned/installed
Thanks in advance
2
permalink
10-13-2008, 09:30 AM
Bikeguy Joe
MODERATOR
Re: Bicycle sprocket + 415 chain?
Yes, if it matches the sprocket, #415 chain is more than sufficiently strong.
3
permalink
10-13-2008, 09:32 AM
NunyaBidness
that my friend is a very good question
I will most likely go to my local bike shop and see if I can find a used sprocket in the parts graveyard and see if it will match up with my chain
it would be nice if someone with more knowledge on this particular subject would chime in with what they know.
Let the solution BE the revolution
4
permalink
10-13-2008, 09:50 AM
velardejose
Hi
36t bicycle sprocket cost: 6 usd
Thing is, chain links length match
I will post my findings
Peace
5
permalink
10-13-2008, 10:27 AM
RedB66
I use them all the time. I try to get the solid ones and drill the holes myself. The hole that is for the crank arm lines up perfectly with the 9 hole gaskets. You have to enlarge the center hole.
BMX Accessories - Solid Chrome 36T Sprocket, bike sprocket, bicycle sprocket, bike chain ring | BikeWorldUSA | Bicycle Parts and Bike Accessories
permalink
10-20-2008, 11:03 PM
velardejose
Hi
Today I visited a friend who has a machine shop
I dissasembled the stock 44t rear sprocket and used it as a template
Enlarged the center hole and drilled 9 holes in the 36t bicycle sprocket
Cut 4 chain links
Reinstalled everything
Tried it slow at first, and as I understood it works perfectly I gave it more gas
My mb rides at low revs at a perfect cruise speed
No more engine vibration
I highly recommend this mod, I am 220 pounds and it has almost the same low end
Peace
7
permalink
10-21-2008, 08:09 AM
Large Filipino
My trike has a sprocket from a donor bmx bike. 40 tooth. I plan on using the 36 tooth currently on my crank and replace that with a 44 or 46.
So yes. It most definitely works.
8
permalink
10-22-2008, 02:57 PM
velardejose
Hi
Pics
44t sprocket (before)
36 t sprocket (now)
It cruises at a higher speed w/o vibration
Had to mod the brake lever, I'll post it in another post
Jose
I am not a complete idiot
Some parts are missing...
Try Google Chrome
http://www.google.com/chrome
What's the black box for?
Gas/oil mix ratio
Show Printable Version
Email this Page
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
vB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
04:56 AM
Miner Skinz.com
Advertisers
Search Engine Optimization by
vBSEO
3.1.0
Contact Us
Archive
LinkBack
LinkBack URL
About LinkBacks
Bookmark & Share
Digg this Thread!
Add Thread to del.icio.us
Bookmark in Technorati
Furl this Thread!
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
