| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Bicycle Motor Refuses to start Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by deacon
My thinking if there isn't too much movement it should help anyway. Maybe keep it ...  | |
04-23-2008, 09:06 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Ottawa
| | Re: Motor Refuses to start Quote:
Originally Posted by deacon My thinking if there isn't too much movement it should help anyway. Maybe keep it from falling out again. | I don't think it came out that easy. The magneto is essentially a magnet and the key is small and was pulled out due to the 2 of them being so close each one. When I pull out the magenta it must of picked up the key as that's where I found the key. |
04-23-2008, 09:14 PM
| | Re: Motor Refuses to start Either way we are back to square one. The key was present and motor still did not work. It be nice to have 2 bikes with a motor on them..However the time i spend on this isn't worth it really. I'm no closer to finding the problem then I was when I started this thread. It's frustrating and helpful @ the same time. I learn more and more about how these things work.
I'm sure if I was shown simple enough I could do proper matienace or simple repair on it. |
04-23-2008, 09:38 PM
| | Re: Motor Refuses to start Try this obviously when the bike ran the key was there, when the key was gone you couldn't get it started. Put the key back with some jbweld and try it again. |
04-24-2008, 05:58 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Motor Refuses to start i think you have come a long way. i have learned alot just reading this thread. get the key in their and it should run. we might have to all put our heads togather to get it running smoothly but at least with the key you should be able to get it to fire up. if you get it running right you will see it was worth the headache and you will know alot more about a bicycle motor then most. |
04-24-2008, 06:05 AM
Originally Posted by Mopedamauter79 I was sure I posted a picture of the key way ..Anyway I will post the pic again.
Here is the pic I took today with my roommate's digital cam. Oh and I FOUND the key! It was stuck to the magneto.
Pic without the key and a picture WITH the key.   | In these pictures - what is that spooge all over your engine and where is it coming from? |
04-24-2008, 06:49 AM
| | Re: Motor Refuses to start Put the key back in with some JB Weld and make sure it lines up with the OLD groove....fill the wallowed out part with JB and let it sit until it's hard (overnight). Then grind away any excess and re-install the mag rotor.
Worth a shot.
04-24-2008, 02:15 PM
Originally Posted by deacon Try this obviously when the bike ran the key was there, when the key was gone you couldn't get it started. Put the key back with some jbweld and try it again. | That's not correct. I clearly stated I had not removed the cover where they magneto was until I exhausted all the suggestions. Therefore during each time I tried to get this junk motor to run the key was present. Quote:
Originally Posted by Pablo In these pictures - what is that spooge all over your engine and where is it coming from? | The green stuff is what's left of the gasket. It was a cheap gasket that feel apart as I removed the cover. |
04-24-2008, 02:40 PM
| | Re: Bicycle Motor Refuses to start how about if the key fell out before you removed the cover that is what we all think happened........back when the bike stopped running that was why you couldnt get it to start...but good luck whatever you decide to do
04-24-2008, 05:15 PM
| | Re: Bicycle Motor Refuses to start Sorry but I'm done with this post I tried to tell you send me it. I'll either fix it or tell you what and why it's not able to be repaired.
04-24-2008, 06:46 PM
Originally Posted by Mopedamauter79 That's not correct. I clearly stated I had not removed the cover where they magneto was until I exhausted all the suggestions. Therefore during each time I tried to get this junk motor to run the key was present.
I think he's asking about the excessive amount of oil on the engine.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:59 PM. | | | Sponsors
