| | bicycle engine Kit - What NOT to do! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. If you wish to contact Don, got to his website and use the "contact us" feature.
Mike...  | |
01-23-2008, 07:45 PM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: Chinese Bike Kit - What NOT to do! If you wish to contact Don, got to his website and use the "contact us" feature.
Mike
__________________ www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
01-23-2008, 08:26 PM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | Re: Chinese Bike Kit - What NOT to do! Got a web address? Thanks! |
02-02-2008, 01:05 PM
| | Re: Chinese Bike Kit - What NOT to do! I think even something as simple as spark gap they got wrong. Instructions say 0.028"-0.034".....well after trial and error and Norm's input (0.020") that is simply too much gap. I went down to 0.022" and it starts and warms up way better. Norm even wrote 0.017"!! |
02-02-2008, 01:15 PM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Chinese Bike Kit - What NOT to do! that is what makes this forum wonderful. i would have never guessed the spark plug gap. its all about helping each other.
02-18-2008, 09:56 PM
|  | Master Motorized Bicycle Builder | | Join Date: Feb 2008 Location: Metro Washington, DC
| | Re: Chinese Bike Kit - What NOT to do! Lots of conflicting info in the manuals. I especially like the part where they stress the importance of mixing the oil and fuel properly and then list the proper mixture as 16 parts oil to 1 part gas
Does anyone have the directions as a Word document? It would be nice to have correct and clear instructions available from this site. |
02-19-2008, 08:15 AM
| | Re: Chinese Bike Kit - What NOT to do! That is something that is sooooo complicated with soooo many variable it would be better in an encyclopedia form with a damn good index.
Frame too large? do this then do that ect. One size does not fit all, on any part of a chineese bik kit. My favorite thing was they didn't bother to tell you enough about the clutch. I thought mine was frozen because it was so hard to activate at first. |
05-19-2008, 10:27 PM
| | Motorized Bicycle Apprentice | | Join Date: Mar 2008 Location: Milbank SD
| | Re: bicycle engine Kit - What NOT to do! Well, I've looked arround here and haven't found an answer to my question. To start with, I have what is supposed to be an 80 cc kit that I bought from a company in Canada. I don't want to mention their name because I'm less than pleased with their service. Anyway, the carb has slots in it where the clamp goes that holds it on to the intake. I have a serious vac. leak there. There is no gasket or o ring to seal it. Is there supposed to be something there? I know some silicone would get me by for now but not very long. Any ideas??? |
05-19-2008, 11:39 PM
| | Re: bicycle engine Kit - What NOT to do! They are all like that. Try sealing it with some form-a-gasket, or RTV. OR get the right size o-ring, but be warned - some o-rings may even make it worse.
I'm not using any goop or o-ring on mine now and it seems to run fine...I may seal it to see if it changes. |
05-20-2008, 04:51 AM
| | Re: bicycle engine Kit - What NOT to do! You can fix that by grinding the carb down so those slots are shorter, or you can seal all the air holes with RTV, I ground the carb down with a grinding wheel and dressed it with a file.
__________________ If it ain't broke, and you mess with it long enough, it will be.
05-20-2008, 06:00 AM
| | Re: bicycle engine Kit - What NOT to do! I bought a box of about ten o rings and put one in it stopped it for me. but you have to get the right size don't put one in that isn't snug cause it will get sucked into the engine they tell me. I had a carb part get sucked in there so be careful. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:05 PM. |
