| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | The *BEST* Solution for "THE" tensioner/pulley Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Very Very nice. Its less welding and more eye pleasing than mine. Good work my man. Thanks for sharing.
If ...  | |
11-03-2009, 01:04 PM
| | Re: The *BEST* Solution for "THE" tensioner/pulley Very Very nice. Its less welding and more eye pleasing than mine. Good work my man. Thanks for sharing.
If I'm seeing this correctly, (master link just leaving rear sprocket?) I'm not being picky here but you should really turn the clip on your master link around. The closed end should enter the engine sprocket first. The way you have it, it can get kicked off by interference with the sprocket/ clutch actuator case. Just an observation that might prevent a chain loss. If I'm seeing it right.
Over Youth and Skill
11-03-2009, 01:10 PM
|  | Motorized Bicycle Elite Member | | Join Date: Dec 2008 Location: CT
| | Re: The *BEST* Solution for "THE" tensioner/pulley Having no pensioner would be nice no doubt but don't forget that no matter how tight your chain is it still may need a tensioner. Ive built 10 bikes now and some have output sprockets that are almost a half inch out of line with the rear sprocket and the tensioner fixes this. It would be a real pain in the butt to fix this problem without it. For the record, i like having a spring tensioner but i have no problem with the stock one. Besides having to bend some to get them to line up there are little to no problems once set up. |
11-03-2009, 01:21 PM
| | Motorized Bicycle Member | | Join Date: Jun 2009 Location: california
| | Re: The *BEST* Solution for "THE" tensioner/pulley No tensioner would be nice and I could have done that, but what I found in my application is that the chain would rub the frame chain stay. By lifting the chain in this area it allows the chain to clear the frame. Sometimes the bike tells you what it needs. |
11-03-2009, 04:23 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: The *BEST* Solution for "THE" tensioner/pulley Quote:
Originally Posted by sportscarpat New around here and my first attempt at a motor bike and my solution to the idler sprocket. I will try to post a picture. Here goes. Well, the attachment worked. I used a #41 Diamond brand chain, an 18 tooth idler sprocket with bearing insert, tig welded a small laser cut tab to the bottom of my frame. The weld on tab is slotted to corectly adjust chain tension. Works great and have had absolutely zero problems. | Very cool! Really like the looks and function. Purty work Sport.
__________________ Quote:
Originally Posted by NEAT TIMES looking In The Sky, May See Dan Flying By!! Ha Ha Ron | I want 2 ride my bicycle |
11-03-2009, 04:39 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: Florida
| | Re: The *BEST* Solution for "THE" tensioner/pulley RELIGIOUS FERVOR?!!!
You want some religious fervor? I'll give you some religious fervor!
Question: Why are Mormons buried EIGHT feet underground?
Answer: The two extra feet is for the bicycle.
Prasinos says above: "Having no pensioner would be nice..." Must be a Republican. Ya
11-03-2009, 04:43 PM
| | Re: The *BEST* Solution for "THE" tensioner/pulley Dang Tom! With glasses on and magnifying glass, (no kidding) still am not sure but think your right. Great catch.
Chain coming apart is a really bad thing at speed. I really can't see if it is reversed though Sportcarpat.
Tom makes fun of me for remembering it as a lil rocket propelling the chain. I remember the ball bearing chain cages on the bottom bracket by; protect your balls, face 'em inward" (LOL, I are slow and actually need these weird lil ways to remember stuff)
11-03-2009, 05:05 PM
| | Re: The *BEST* Solution for "THE" tensioner/pulley I bet he's got a 5' monitor... geez
Good eye Tom lol |
11-03-2009, 06:02 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: colorado
| | Re: The *BEST* Solution for "THE" tensioner/pulley With IE8 you can magnify up to 400x by 1 click on the bottom of the screen. |
11-03-2009, 09:16 PM
| | Re: The *BEST* Solution for "THE" tensioner/pulley my best bud is blind and uses "zoomtext" doubt he would have cought that. Amazing Tom
11-03-2009, 11:16 PM
| | Re: The *BEST* Solution for "THE" tensioner/pulley Photo Shop...I can ANYTHING with Photo Shop. Actually I saw his master link on my old 80s vintage monitor at work. I downloaded that pic to PS and enlarged, enhanced it and used a shapening filter. It looks like its backwards but I'm not absolutely positive. I'm still waiting for a reply from him to confirm.
Over Youth and Skill | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:49 AM. | | | Sponsors
