| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | baffle trouble Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. has anyone ever had trouble getting out there baffle if so can you tell me how to get mine out ...  |
07-21-2008, 09:00 PM
| | Motorized Bicycle Apprentice | | Join Date: Jul 2008
| | baffle trouble has anyone ever had trouble getting out there baffle if so can you tell me how to get mine out i have taken off the retaning srcrew but after that it will not budge i have tried putting vice gribs on there and lightley hit it with a hammer still will not come out any ideals thanks |
07-21-2008, 10:29 PM
| | Re: baffle trouble Welcome to the forum
I do not have trouble with mine. I've seen some with the bolt and welded at the same time. Be sure your's is not welded also.  |
07-22-2008, 10:55 AM
| | Re: baffle trouble take the retaining screw out fire it up and ride it it will fall out. Be careful not to run over it. This is the easiest way I've found to remove a stuck baffle. |
07-22-2008, 12:22 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: baffle trouble Quote:
Originally Posted by Norman take the retaining screw out fire it up and ride it it will fall out. Be careful not to run over it. This is the easiest way I've found to remove a stuck baffle. | That was some of the best advice I've ever heard!!!
You are sooo right, I don't care how rusted in that baffle is.... Without that screw, it will fall out in the street!!
07-22-2008, 02:04 PM
| | Re: baffle trouble you got it!  |
07-22-2008, 02:38 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: baffle trouble Is it the exhaust pressure making it come out while riding, or the heat expanding the pipe and letting it come out easily? |
07-22-2008, 02:59 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: baffle trouble Both. If you iake some screen wire and put it over your pipe and make it like a sock, then attach it so the baffle will fall into it and not on the ground You won't run over it, or burn your hand when you pick it up, like I did  I wrap felexable wire around the screen and pipe to hold it. Does the forum look narrower? or have I finely lost my poor mind?
No matter where you go, or what you do, there Ya' are! |
07-22-2008, 05:24 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: baffle trouble I think its because cruiser is experimenting with ads on both sides of the page ...making the center narrower
Bill (aka azbill, aka azkronic)
yesterday is history,
tomorrow is a mystery,
but today is a gift...
that's why it's called "the PRESENT" |
07-22-2008, 06:42 PM
| | Re: baffle trouble Good thing! I thought my beer was gettin weaker!!!  Later Tramp
07-23-2008, 04:48 PM
| | Re: baffle trouble its the castor oil fumes makes all thing smaller
good idea on a catcher for the baffle I didn't go far before mine came out. the heat and the pressure along with the vibs all work together to make it come out. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:53 AM. | | |
