Availability of 6mm 9-bolt rag joint sprocket mount parts
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello forum members, I was looking online today for replacement parts for the 9 hole,6 mm bolt, sprocket rag-...
Old 05-21-2008, 10:20 PM
Motorized Bicycle Apprentice
Question Availability of 6mm 9-bolt rag joint sprocket mount parts
sprocket rag-joint mounts for 36-spoke 26 inch wheels;I have only found the sprocket mounting kit as a complete kit,but no replacement parts for these kits!!
I would like to know if there any online sources for replacement parts-namely ragjoint gasket/9 hole rag-joint clamp-for the 36 spoke mounted sprocket
mounting bracket???
Thanks in advance for any replies!!!
Old 05-22-2008, 07:19 AM
Bikeguy Joe's Avatar
Default Re: Availability of 6mm 9-bolt rag joint sprocket mount parts
Have you contacted the sellers of these bicycle motor kits to see if one would sell you a set?
Old 05-22-2008, 10:57 AM
Smile Re: Availability of 6mm 9-bolt rag joint sprocket mount parts
No,I have not;I will consider that in the near future.
Thanks for the reply!
I am thinking for the money,it probably would be cheaper to order a sprocket mount kit
as a spare since any replacement parts would have to be fabricated!!
Old 05-26-2008, 07:08 PM
Andyinchville1's Avatar
Manufacturer/Dealer
Hi Robo,
Is your 6mm mounting kit from Kings (not affiliated with me)?.....Seems that most of the people who have bought sprockets with the smaller bolts have gotten them from them (Kings)...I think Dax sells both setups (6 MM and 8 MM) for something like $14.00...you might want to check him out....He's good to deal with (Duane).
Hope this helps you.
Andrew
Sprockets now available in 9 anodized colors!
http://www.myspace.com/kingssalesandservice
http://www.youtube.com/watch?v=-zyU8n41f2c
Similar Threads
The Ultimate Hub for Direct Sprocket Bolt Up Andyinchville1 High Performance Bicycle Engine Tips 16 07-03-2008 10:07 PM
Hot Whizzer Parts Quenton Guenther Swap Shop 4 06-10-2008 06:40 AM
Project parts bike Turner Introduce Yourself 7 05-19-2008 06:49 PM
kings sprocket mounted to disk brake mount CRUISER Motorized Bicycle General Discussion 5 05-13-2008 05:45 PM
Need bike parts sisdavid Swap Shop 6 04-20-2008 05:35 AM
