Originally Posted by flybytaco yes sir. i think its bullet proof but would like to try something different no shift kit just to center motor and i dont really want to use 40 chain are there sprockets for a 415 avail I used a 10 tooth and 12 tooth to rear sprocket 10 and 10 from motor to jack |
Thats why I built mine so I could center the motor, and have two short chains rather than the super long one. I built mine with #41 chain and sprockets. That is what I used 10 tooth & 10 tooth then 12 to the rear. I found a place on line where you can order any sprocket you want plus 5/8 jackshafts with a 3/16 keyway cut in them. Also the 5/8 X 1 3/8 sealed bearings. The price and shipping is really reasonable. I just used some chromoly tubing, and bored it for the 1 3/8 bearings. It worked out so sweet.
John
