all spokes are loss and wheel wobbles side to side
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. HI on my bike all of my spokes are loss and the wheel wobbles side to side. Can i fix ...
Old 10-27-2008, 01:07 AM
4wdingman's Avatar
Default all spokes are loss and wheel wobbles side to side
HI
Can i fix this? I might just buy a new wheel but how can i stop this happening?
Thanks
Old 10-27-2008, 07:52 AM
Bikeguy Joe's Avatar
Default Re: all spokes are loss and wheel wobbles side to side
You can fix it.
Truing up a wheel is not hard if you have a little patience. Google "wheel truing" or "how to true a wheel". There may be a few posts here too, not sure.
The way to avoid having all your spokes come loose is check them on occasion and tighten as needed. Also, zip ties at each cross help immencely.
Stay out of the rough stuff.
Old 10-27-2008, 01:10 PM
fairracing31's Avatar
How To True a Wheel - Bicycle Tutor
Old 10-27-2008, 10:04 PM
cachehiker's Avatar
Cheaper wheels are hit and miss with their initial tensioning. Too loose and the nipples on the ends of the spokes will loosen over time. Too tight and the spokes will break at the bend where it's attached to the hub. A little of both and you get a little of both. Usually the loose spokes loosen up until the tight spokes are carrying too much of the load and start breaking. I have a few sets of anal retentively tensioned, hand built wheels that I beat the "snot" out of and with one exception, they've never once gone out of true.
My local bike shop will true a wheel for $5 and retension it for $12. However, if the rim is already damaged, they will be unable to evenly tension the spokes and no amount of work will keep the wheel true for an extended period. If that's the case, decent cheap wheels can be had for about $30 front and $45 rear and the shop will likely check the tensioning and fix it if it's wrong for free.
