Air in Gas Filter
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Air in Gas Filter I changed my gas filter but now the new on has air in it, Will this ...
Old 06-21-2008, 02:38 PM
Default Air in Gas Filter
Air in Gas Filter
Will this cause problem?
And if so how do I remove the air?
Old 06-21-2008, 02:49 PM
fairracing31's Avatar
Default Re: Air in Gas Filter
Hmmm...normally the air would work itself out...pull your fuel line off from the carb, hold fuel line down toward's the ground, open the fuel till fuel pours out...put your finger over fuel line then shut fuel off and remount hose to carb.
They only time I had problems with air in the filter is when I used to big of a fuel filter.
Hope this help's
Old 06-21-2008, 02:54 PM
I just changed it and only tested it for a couple of miles I will wait and see if the air works itself out first. Thanks for the quick reply.
Old 06-21-2008, 02:58 PM
Oh... I was just looking at your pic again...look at the filter...the outlet is higher then the inlet... you need to get it pointed down a little more somehow there.. that will help alot.
Old 06-21-2008, 07:55 PM
deacon's Avatar
Mine always has air first think in the morning
and the bike always runs fine
I think it has to do with the gas leaking out of the line over night and air filling in. the filter is below the cutoff.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 06-22-2008, 09:02 AM
Bikeguy Joe's Avatar
MODERATOR
It won't hurt a thing. You should get the outlet side lower than the inlet side though.
Old 06-22-2008, 09:57 AM
Pablo's Avatar
Originally Posted by MarcPhotoMan View Post
Air in Gas Filter
Indeed. Nothing to worry about at all. Mine has way more air than that. The filter is huge relative to the about of fuel that needs to flow. All you need is a tiny trickle of fuel to keep the bowl full, I'll bet in the 3rd world countries the intank filter is 90% clogged and the owners aren't even aware of it.
BUT I agree with BGJ - looks like gravity feed may be a problem.
Old 06-22-2008, 08:52 PM
deacon's Avatar
Ignore the air... It is normal.
Advertisers
