Re: after run in oil to gas? If you are running a bushed engine, go with 24-32 to 1. Bearing engines 30-32 to 1.
Also, look at your plug, you may be running with the carb too rich.
Leaning the oil to fuel mixture will richen the fuel to air mixture.
