| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | 80cc Mystery Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by MrLarkins
float level is at its maximum
fuel filter queen
jet in carb is clean
float needle ...  | |
06-23-2008, 03:36 PM
| | Re: 80cc Mystery Quote:
Originally Posted by MrLarkins float level is at its maximum
fuel filter queen
float needle in carb is clean
QUESTION:
is it possible that a misbalance on the inside might cause a rpm threshold? |
I doubt it's a misbalance - I think your needle taper could be ODD. Tell me this, in the video - when you get to the nasty early midrange flutter - if you hold it there, does the engine die? |
06-23-2008, 03:52 PM
|  | HS Math Teacher | | Join Date: Jun 2008 Location: arkansas
| | Re: 80cc Mystery hmm, i'll check |
06-23-2008, 06:33 PM
| | Master Motorized Bicycle Builder | | Join Date: Jun 2008
Originally Posted by misteright1_99 You are definatly lean... Look at the pic of the spark plug, Might want to raise the needle in the carby (lower the clip) one slot......Parts all look ok though. Also when you put the piston back in the cylinder make sure you line the opening of the rings up with the little pins in the grooves...
8oz @ 20:1 = 160oz of gasoline 128oz = 1 Gallon So 8oz of oil to 1 Gal and 1qt of Gasoline
Any QUALITY oil..... I use Amsoil Sabre.... | Mr. Right,
I am not a mathamatician nor a mechanic to speak of, but I
am thinking 128 oz Divided by 20 = 6.4
so 1/20th would be 6.4 ?
Right ?
Reason: spelling
06-23-2008, 06:44 PM
Originally Posted by Pablo I doubt it's a misbalance - I think your needle taper could be ODD. Tell me this, in the video - when you get to the nasty early midrange flutter - if you hold it there, does the engine die? | no, the vibration is so bad though that gas comes out of the carb through the primer! |
06-23-2008, 07:31 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
Originally Posted by MrLarkins I will also mix a new back of fuel, 20:1 (real quick, how many gallons of gas is that to 8 oz or oil?)
what brand of synthetic should I be using? best? | Quote:
Right ? | I am not a mathmatician either so I use a calculator lol. I believe though, I entered the figures correctly. He has 8oz of oil and wants it mixed 20:1. So
8 x 20 = 160 or 1 gallon and 1 quart 128 + 32 = 160. Correct? Sorry if I calculated wrong.....
06-23-2008, 07:35 PM
| | Re: 80cc Mystery OK, but double check, I have a gallon of gas I need X amount of oil for a 20:1 ration, so 128/20=6.4 oz.
Right Sir ? |
06-23-2008, 07:44 PM
Originally Posted by Wheel Rush OK, but double check, I have a gallon of gas I need X amount of oil for a 20:1 ration, so 128/20=6.4 oz.
Right Sir ? | You are correct but his question was "I have 8oz of oil, How much gas for 20:1"
06-23-2008, 08:09 PM
Originally Posted by MrLarkins no, the vibration is so bad though that gas comes out of the carb through the primer! | Argghh...but hard to determine if this is a cause or effect..... |
06-23-2008, 09:26 PM
| | Re: 80cc Mystery rgr that...bikes tore apart for two days whilest the rear wheel is in the shop for axel/freewheel repair and bearing overhaul! |
06-23-2008, 09:30 PM
| | Re: 80cc Mystery you must have a flywheel let loose if its shaking the fuel out of the carb at least that is what I'd look for but to do that you need to take it apart and possibably split the crankcase. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:23 AM. | | |
