| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | 80cc Mystery Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by misteright1_99
Read the first paragraph one more time CAREFULLY!!!!!!!
hmm, i read it 3 times, and I ...  | |
06-23-2008, 10:48 AM
|  | HS Math Teacher | | Join Date: Jun 2008 Location: arkansas
| | Re: 80cc Mystery Quote:
Originally Posted by misteright1_99 Read the first paragraph one more time CAREFULLY!!!!!!! | hmm, i read it 3 times, and I still read the same thing... Quote: |
Originally Posted by misteright1_99 you might want to try moving the clip ONE notch and riding your bike and see what you think. And then MAYBE try another slot and TEST RIDE ETC. Looking at that spark plug I think you are running lean so you should start with moving the clip DOWN 1 slot to increase fuel to air mixture.... | it still says move down 1 slot, as I did...pablo says move to top spot (up, not down)
what am i missing? now i'm really confused. heck, i'll just try all slots! |
06-23-2008, 11:19 AM
Originally Posted by MrLarkins hmm, i read it 3 times, and I still read the same thing...
Previously you wrote: Quote: |
Originally Posted by MrLarkins ...it gets more gas (hence the black, oily spark plug), .......acts like its flooded. | So....based on this I THINK you need to be more fuel lean.....moving the e-clip up makes it more lean mid throttle by keeping the needle lower in the carb jet path.
What Norm says is correct. |
06-23-2008, 11:29 AM
| | Re: 80cc Mystery Also - what the other guys are saying (and I'm not necessarily disagreeing with them) - based on the initial plug pictures, it looks a bit lean. But your engine is back together and we have moved beyond that, right?
Seems to me you should try the top notch or the second notch and go from there. It's gonna turn out that your issue has nothing to do with the needle groove.
Where did you get your new gaskets? |
06-23-2008, 12:26 PM
| | Re: 80cc Mystery ok, i am such a noob...you guys are a bunch of help! top notch it is
and just for the record, the wording lends itself to be confusing...i mean really... Quote: |
Originally Posted by pablo more fuel lean | i'm getting it now, but thats confusing...more fuel...lean? how bout, more air or less fuel
06-23-2008, 01:18 PM
Originally Posted by MrLarkins ok, i am such a noob...you guys are a bunch of help! top notch it is
i'm getting it now, but thats confusing...more fuel...lean? how bout, more air or less fuel | That's just bad word choice on my part (sorry), but I meant what I said....IOW - more leaner, or just leaner…….less fuel = more leaner=more fuel lean….crazy asss English langauge…
Properly, moving the clip to the top, without changing other parameters will result in less fuel in the air/fuel mix.    |
06-23-2008, 01:21 PM
| | Re: 80cc Mystery i moved it to the top...no effect on problem
i don't need to be moving to have the problem occur. standing still with clutch engaged, i can turn the throttle and at some point, the motor starts acting up...maybe I can get a video of it soon |
06-23-2008, 01:39 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: 80cc Mystery Sounds like it is starving for fuel and since you moved your clip up and down the needle and that didn't work here are a couple of things to try.
Float level too low causing fuel starvation at above idle condition
Plugged fuel filter either in tank or auxiliary if you have one.
Clogged jet in carb.
Clogged float needle in carb. |
06-23-2008, 01:57 PM
| | Re: 80cc Mystery Quote: |
Originally Posted by Pablo It's gonna turn out that your issue has nothing to do with the needle groove. | OK I agree with Ghost0 (imagine that) it sounds like fuel delivery is impeded - I wonder now maybe the taper of the needle is funky. Do all the easy stuff first...make sure fuel is flowing well.
Oh yeah - thanks for the video - it really helps with the troubleshooting. |
06-23-2008, 03:09 PM
| | Re: 80cc Mystery float level is at its maximum
fuel filter queen
jet in carb is clean
float needle in carb is clean
QUESTION:
is it possible that a misbalance on the inside might cause a rpm threshold? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:17 AM. | | |
