| Sponsors
| | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | 80cc bike engine has no power :( Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by bvCrimson
Anyone know what the true bore is on these "happy time 80ccs" from PowerKing?
07-24-2008, 08:51 PM
| | Re: 80cc bike engine has no power :( Quote:
Originally Posted by bvCrimson Anyone know what the true bore is on these "happy time 80ccs" from PowerKing? | I had it somewhere....I'll have to find it and post it later |
10-02-2008, 05:53 PM
| | Motorized Bicycle Apprentice | | Join Date: Oct 2008
| | Re: 80cc bike engine has no power :( maybe i,ll check there also as i have the same damn problem... no power and the thing only poops along. have to peddle like a demon to get up hills. |
10-02-2008, 05:58 PM
| | Re: 80cc bike engine has no power :( these chinese motors, lets face it, do not have any quality control.. perhaps a lot of different problems elsewhere inside engine; ie: rings;pistons; electric cdi box; the low power and cutting out problems could either be related to the cdi or bad carb jets. dunno...i have the "no power" problem on the slighest hills...ran good for awhile then crapped out. starts fine and begins fine;;then..putt.putter, putt, putt: blah!! |
10-02-2008, 06:38 PM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008
| | Re: 80cc bike engine has no power :( Sounds like a carb problem Twaddles, could be the float is not letting enough fuel to fill the bowl up. Could also be dirt in carb, at idle there is enough gas but when you need more gas, it can't deliver it fast enough and it bogs out. Did you use a fuel filter?
I would not even start mine without one, the gas tanks are nasty on the inside. |
10-02-2008, 08:31 PM
| | Re: 80cc bike engine has no power :( Thanks, Toytime... Appreciate Your Reply.. Yes, I Placed A Fuel In Line Filter And It Did No Good. I Also Took The Carb Apart And Checked It. Seems O.k... It Stutters And Jerks Along With No Power, But When I Let Up On The Throttle It Smooths Out!!! Go Figure!!! Strange As The Stock Market ...(lol) It Worked O.k. A Day Ago.. Then When I Put The Fuel Filter In... Horrible... I Don,t Know,, I Am About To Get Another Stripped Kit With Just Motor And Carb And Cid Unit... Somethings Gotta Work..(i Hope...) Whaty Do You Think??? Twaddles |
10-02-2008, 09:09 PM
|  | Master Motorized Bicycle Builder | | Join Date: Sep 2008 Location: North Plainfield, NJ
Originally Posted by twaddles Thanks, Toytime... Appreciate Your Reply.. Yes, I Placed A Fuel In Line Filter And It Did No Good. I Also Took The Carb Apart And Checked It. Seems O.k... It Stutters And Jerks Along With No Power, But When I Let Up On The Throttle It Smooths Out!!! Go Figure!!! Strange As The Stock Market ...(lol) It Worked O.k. A Day Ago.. Then When I Put The Fuel Filter In... Horrible... I Don,t Know,, I Am About To Get Another Stripped Kit With Just Motor And Carb And Cid Unit... Somethings Gotta Work..(i Hope...) Whaty Do You Think??? Twaddles | pull the spark plug out and shake it. do you hear anything? if you do chuck it in the garbage and get a new one. i had a similar problem. it turned out to be the electrode broken on the spark plug causing the gap to change when it wanted (your engine will run better with a wider plug gap start small and widen it as much as possible until it starts to misfire then close it up just a bit) i replaced the spark plug and it ran great after wards. in my opinion the first thing that you need to do to your kit is change the spark plug and ad a fuel filter. The stock no frills plug just wont last. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:45 AM. | | |
