Re: 3 Piece Wide Crank?? Thanks for the measurement.
Saying you would have to cut the crank to replace it I assume is because the bearing retaining flange is on the right side and that side would not slide out because of the bearings?
Did you bend the crank while it was on the bike?
Guessing if the offset had been put in the crank of the bearing flange side it would still be removeable?
Too much space in my head to ask questions. ) Semi-retirement does have its pitfalls.
Jim
__________________ Easy does it, but do it! |
