| | | The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like. | Switch Cluster. Light, Indicator, Horn etc Discussion at Motorized Bicycle Engine Kit Forum in the The Tavern forum. Have found this part listed on eBay, any ideas if it could work? Would want it running of a battery ...  |
01-10-2009, 08:45 AM
|  | UK Dealer | | Join Date: Jun 2008
__________________ For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
01-10-2009, 10:44 AM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: Houston
| | Re: Switch Cluster. Light, Indicator, Horn etc Sence it has no speed control you could use it with and voltage you want, It is just switchs I would go for it if you like the set-up. Might even thread the wires thru the handle bars and make it real clean.
Always do a pre-ride check. Make it a habit, and ride safe. |
01-10-2009, 11:01 AM
| | Re: Switch Cluster. Light, Indicator, Horn etc Tah for that, really cautious as i know diddly squat about electronics!
01-11-2009, 01:55 AM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Las Vegas NV USA
| | Re: Switch Cluster. Light, Indicator, Horn etc its just switches is exactly right you can use any voltage lights you want these are grounding switches so you would run a primary positive voltage in parallel just meaning a shared positive from the battery source then connect the grounds of the lights to the switch cluster and the switch cluster should have a master ground. you can do it the opposite if you want but i would rather float the ground then run the power thru the switch.
There is my two cents |
01-11-2009, 05:51 AM
| | Re: Switch Cluster. Light, Indicator, Horn etc Thanks Huffy, i'm now buying in a horn and rigging up lights and indicators
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:49 AM. | | | Sponsors
