Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
help me decide
Discussion at Motorized Bicycle Engine Kit Forum in the The Tavern forum. I have been trying to decide what speedometer to buy for my bike. I'm not sure I want a ...
Old 03-28-2008, 11:58 AM
deacon's Avatar
minor bike philosopher
Default help me decide
I have been trying to decide what speedometer to buy for my bike. I'm not sure I want a digital lcd type cause they can be hard to read in the sunlight and they look way to modern for my old bike. I have given some thought to this one
what do you think
Bicycle 26" & 27" Speedometer Cruiser Bike NEW - eBay (item 140218517664 end time Mar-31-08 16:44:41 PDT)
Me and the Ebike
New Novel in progress blog...
Old 03-28-2008, 12:43 PM
Autocycler's Avatar
Default Re: help me decide
I bought a speedo that looks identical to this one, and it worked well for a few weeks, but then became less and less accurate for some reason...stripping of internal gears maybe?? It couldn't handle running at higher speeds for long distances.
If you cruise around at 20mph or less, I think it will work fine for you.
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Old 03-28-2008, 01:10 PM
I bought a schwinn digital speedo at Walmart for $10.00.
Old 03-28-2008, 02:42 PM
deacon's Avatar
all they have here is the bell digital.
Me and the Ebike
Old 03-28-2008, 02:43 PM
deacon's Avatar
If i see one at walmart tonight I'll pick it up otherwise I guess I'll give this a try.
Me and the Ebike
Old 03-28-2008, 06:28 PM
deacon's Avatar
okay I found a digital at walmart... i bought it. I will use it on one of the bikes for sure but now I have a question. It doesn't say in the directions if the magnet has to be mounted in any particular position on the spokes. yeah it said close to the receiver but... Seems to me it also has to be at the outside edge of the spoke. To give the wheel the right amount of time for the speedometer to guage the amount of distance per second. Does it make a difference?
Me and the Ebike
Old 03-28-2008, 07:08 PM
you mount the magnet on the spokes with the flat part (assuming it has a flat part) facing the inside of the fork, which is where the other part of the speedo should be. The two parts must be very close in order for it to work. I had a very difficult time getting mine close enough to work. I finally wrapped pieces of inner tube around the fork leg and secured them with plastic ties. The rubber will help keep the receiver from slipping.
Old 03-28-2008, 07:14 PM
deacon's Avatar
Yes I figured that but does the magnet have to be near the outer edge of the wheel so that the rotation is the full length of the wheel to get an accurate speed reading
Me and the Ebike
  #9 (permalink)
Old 03-28-2008, 07:21 PM
deacon's Avatar
here you go one or two or does it matter
Me and the Ebike
  #10 (permalink)
Old 03-28-2008, 07:23 PM
MY diagram showed the magnet near where the spokes cross. this might also help keep them in place, I also used gorilla glue to help keep in place after I had it tightened.
