Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
A/C
Discussion at Motorized Bicycle Engine Kit Forum in the The Tavern forum. Would I still have to vacume it out and that sort of thing before re-charging?...
  #11 (permalink)
Old 06-12-2008, 09:05 AM
Default Re: A/C
  #12 (permalink)
Old 06-12-2008, 09:44 AM
misteright1_99's Avatar
Default Re: A/C
If there is still pressure in the unit you would not need to pull a vacuum. You would want to purge the hose of any air with refrigerant as you screw the hose onto the unit...
  #13 (permalink)
Old 06-12-2008, 10:42 AM
Default Re: A/C
the thing to know here, is that if you're charge is low, you have a leak somewhere. if you pull a vaccum, you will pull moisture into the system. you have to find that leak, or be ready to keep adding to your charge. it may work for a while, (depending on the size of the leak). when i leak test a system, i remove the remaining charge, pressure the system to about 250-300 psi. i use an inert gas, sush as carbon dioxide, or dry nitrogen, then go over the sealed system solder joints,with a solution of dishwashing liquid, & water. look for oil , this is often the sign of a leak. if you can find the leak, you have done the half the work, & often the most difficult half. although most leaks are repairable, some are not. i would suggest repairing it, ( if possible.)
  #14 (permalink)
Old 06-12-2008, 10:59 PM
Saddletramp1200's Avatar
Default Re: A/C
I have to put quarters in mine and turn that little knob.
  #15 (permalink)
Old 06-13-2008, 09:03 AM
Default Re: A/C
so do i, i just pay all mine at the end of the month
Advertisers
