| Sponsors
| | | | | Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work. | Welding Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. Is it at all possible to weld these engines to the bike. Another way I could think is weld the ...  | |
06-23-2008, 04:11 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Ottawa
| | Welding Is it at all possible to weld these engines to the bike. Another way I could think is weld the metal bracket piece the bolts go through before they screw into the engine to keep it secured to the frame. I figure if it's welded on the bike then I would never have to worry about it coming loose the bolts or it viberating to much either.
I'm still trying to figure out how to get that stuck bolt out of the engine. |
06-23-2008, 04:53 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Welding I wouldnt weld the motor to the frame. Drill the bolt and use an easy out, or cut a slot in the broken stud (if it is flush) and then you can heat it a bit and unscrew it.
06-23-2008, 04:59 PM
| | Re: Welding I don't think you can weld aluminum to steel unless there is a some magic formula I'm not aware of...which is possible.
06-23-2008, 06:03 PM
| | Re: Welding as far as I know you can weld anything to anything...melting two metals and letting them dry together? sounds right to me, in anycase we're going to have to take the darn thing in somewhere to get this bolt out, so frusterating...
- Mopedamauter79's gf |
06-23-2008, 10:22 PM
| | Re: Welding I've started this just for moped....it's just a start but more to come... How to fix broke stud/bolt
Moped GF...you might as well register and have your own user name...
Why not  |
06-23-2008, 10:34 PM
| | Re: Welding 'Cause once I get his bike fixed I wont need to post anymore, just seems like wasted effort.
-Mopedamauter79's gf |
06-23-2008, 10:42 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Welding Or you could always get your own username, fix his bike, then build one for yourself  |
06-24-2008, 12:08 AM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Decatur,IL
| | Re: Welding have you tried a easy-out there so easy! drill a small hole in your broken stud then use the easy out , it catches counter clockwise so you can remove the broken stud.
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
06-24-2008, 02:55 AM
| | Re: Welding Quote:
Originally Posted by filestyle1 have you tried a easy-out there so easy! drill a small hole in your broken stud then use the easy out , it catches counter clockwise so you can remove the broken stud. | We tried to drill into the bolt but the drill wont drill a hole. The best we are able to do is put a small dent into it. I dunno if the drill is not strong enough or you need a drill bit that will drill into steel. |
06-24-2008, 06:56 AM
| | Re: Welding You will need a decent drill bit, not a dollar store bit or a "multi-purpose" bit. Use some oil as you drill, light pressure, lower speed if possible.
The difference between using a good bit properly and a crappy one improperly is amazing.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:50 AM. | | |
