Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Paint Booth & Chop Shop
Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work.
Pea soup headlight
Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. SB on the top side of the small can I will have 2 shaped sheet metal mounts that reach up ...
  #11 (permalink)
Old 11-05-2009, 08:29 PM
Rockenstein's Avatar
Default Re: Pea soup headlight
SB on the top side of the small can I will have 2 shaped sheet metal mounts that reach up to where the fork legs, struts and spring assembly bolts together. I'll also have a mount of some kind coming up from where the fender bolts to the steering tube attaching to the bottom side of the small can...this will be where the angle adjustment is made and secured.
How do I cut the cans?
I use curved scissors similar to what is pictured below, I get them for $1.50 at a surplus store and they work just great on thin sheet metal too. Before cutting I mark up with either a fine sharpie or tool makers ink and a fine scribe. To dull the edges of a fresh cut I use my Dremel with a fine stone bit then I finish off with some fine sandpaper...freshly cut cans have edges sharp as a razor!
I refuse to be taken apart...
  #12 (permalink)
Old 11-05-2009, 08:59 PM
silverbear's Avatar
Yes, I can see that scissors would work and good to get cheap ones since they will dull pretty easily that way. My own projects are on hold for awhile as I am packing up for my annual snowbird migration to western Maryland. I'm taking four bikes with me, a couple motors, leather and tools to keep me out of trouble. I work as a caretaker/ handyman at a rural home not far from Camp David for a few months throught the winter. This year I'll be converting the rear portion of the main house into an apartment. Last year I always knew when Obama was going for the weekend as there would be military helicopters flying over in a grid long before his own would fly over. I waved and like to think he waved back. Howdy, pres.
You know, regarding your apple jiuce and now pea soup/ mushroom can projects. Unless somebody has done it themselves they have no idea what pleasure it is to make something out of nothing, especially when you have thought it up yourself. There's nothing like it. Just a great satisfaction. Nice going, my friend.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
  #13 (permalink)
Old 11-06-2009, 05:18 AM
BarelyAWake's Avatar
I see now that you did mention a "visor" but I still wanna say I think yer headlight came out great, I agree makin' yer own bezel looks far better, I can't wait to see it with the "eyelid" - I've always been fond of 'em lol
  #14 (permalink)
Old 11-07-2009, 04:00 AM
Thumbs up Re: Pea soup headlight
Thanks SB, making something up pretty much as you go and ending up with a working product that you can say is uniquely your own is enjoyable to say the least. Seeing the finished product of others that might happen to get inspired by a project such as this is very cool too
So since I'm mounting the lens without the aid of the original shroud I needed to get it sitting in the can flush, snug, centered and somewhat sealed. The method that I came up with to accomplish those things is a leather gasket sealing against the rim of the can plus the ID of the trim ring/visor part that's yet to be cut and put in place. Sealing and centering the lens to the ID of the can is a strip of Felpro's cork gasket making material, I feel I got lucky as it was the perfect thickness to do the job! Bonding the leather and the cork to the lens was done with contact cement applied with a small'ish tipped artists paint brush. To get the ID of the leather gasket cut out in a reasonably neat fashion I used a paper template tacked to the leather via a glue stick. Took me a couple of tries to get the ID of the gasket right but hey I got a whole couch worth of leather to play with...lol! I'll trim the OD of the leather gasket later when I get the trim ring/visor part attached. Next part I'll be working on is the rear mount which will allow me to secure the lens and service the light if required.
  #15 (permalink)
Old 11-07-2009, 08:30 PM
Good work! I think I'll drop by my recycling center tomorrow (no customers to bother me on Sunday) and see what I can find. I've been dreaming of gas tanks and lights made from 3"-4" copper pipe.
I've also got some interesting PVC scraps I'm thinking of using.
-RecycleBill, Greensboro, North Carolina's EZM dealer http://www.EzGreensboro.com
  #16 (permalink)
Old 11-07-2009, 08:42 PM
I'd use rockenstein's light over a bullet style any day! awesome job
  #17 (permalink)
Old 11-08-2009, 10:26 PM
A little more progress was made today...was scratching my head for a while trying to come up with a simple method of securing the lens to the cans. Had lots of elaborate over engineered ideas but since this thing isn't going up on the next shuttle mission I gave my head a shake and came up with something simple...and cheap...lol
I took a 3/8" x 1" 1/2 fender washer and bored the center out so it matched the OD of the area on the back side of the lens I wanted to connect to. I then drilled 6 holes in the washer, 4 1/16th holes for closing the 2 halves back together with a length of copper wire once they are in position and 2 #29 holes for the 6-32 x 2" screws that go through the 2 #29 holes drilled into the end of the small can. After the boring and drilling was done I split the washer with a hacksaw and cleaned up the ends. I made a couple leather washers to go under the regular washers used on the outside of the small can just to help seal things up against the weather. I will eventually put a dab of securing solder on the 2 copper wires used to close the washer halves together but I'll wait and do that when I'm ready to button the thing up for the last time before mounting. Too I need to make a better and more secure E10 type bulb socket so there may be a need to disassemble everything once or twice yet. The pictures should give you all an idea of how it goes together and where I'm at with the project.
Cheers till next time
pea-soup-headlight-light-8.jpg  pea-soup-headlight-light-9.jpg  pea-soup-headlight-light-10.jpg
  #18 (permalink)
Old 11-09-2009, 01:54 PM
diceman2004's Avatar
that looks sweet rock , kinda reminds me of those big bulky flashlights we had as kids that took 4 D size batteries and lasted about 2 hours
  #19 (permalink)
Old 11-09-2009, 01:57 PM
i,m still waiting for someone to make a sardine can magnito cover
  #20 (permalink)
Old 11-09-2009, 06:03 PM
K.i.p's Avatar
Nice engineering and fabrication. That is going to be one nice retro headlamp!
