Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Paint Booth & Chop Shop
Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work.
my 700c single speed 2 stroke 80cc
Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. man from what i delt with on one dont get a used worn out frame stay away from bumps and ...
  #21 (permalink)
Old 01-13-2009, 04:20 AM
turbo/chaos's Avatar
Default Re: my 700c single speed 2 stroke 80cc
man from what i delt with on one dont get a used worn out frame stay away from bumps and be scared of corners at fast speds but on the straits give it all its got
the past is a blueprint for the future
i am turbo chaos of Gaijin MB Productions
dax 65cc type d top speed stock 50mph
PK 1st gen speical edition top speed 50mph 40t stock kit 10k later dead
  #22 (permalink)
Old 07-02-2009, 08:09 PM
i got the single speed flil flop too thats the kinda bike i wanna build
  #23 (permalink)
Old 07-02-2009, 11:00 PM
I like it!!
I am waiting for my first engine to arrive. The bike I have is also a road bike. Its an old Hiawatha from Gambles. I would rather find a bike with wider tires and a better seating arrangement for an old guy but if I am not mistaken I can later remove all the parts without ruining the bike and put them on a differant bike (is this correct)?
But I want to ask you how you like the ride on the narrow wheels and hunched over position?
  #24 (permalink)
Old 07-03-2009, 01:37 AM
ok one i ride fixies alot now so check that out to did you get a origin 8 flip flop hub or did you get a furmula hub and also did you get the 63cm high flang or a low fland if high the you have to grove the hub for the cog to fit
and you can fita 700c on a 27inch frame and still use the stock parts for the bike to work there is like no difrence and if you go with the deep v rims make sure you get MSW wall rims so you can use the brakes
now i dont know if bird dog motors still makes it but i saw one time they where seling a free spin setup that treaded to the flip flop hub and it came in locked setup also (i think)
but if you whant a cheap good frame to use check out origine 8 great good stunt frames to use for fast speeds
im going to be working on one that will be a origine 8 uno frame with low flang bmx 48 spoke track hub spoked to a sun rim mamonth XL 700c with 35c tires on a 56t to 28-11 gear setup 6 speed with the shift kit from sick bike parts armadeilo tires with twisted oddeesy peddals with sugino crank and BB setup with cerramic bearing hubs not cheap but will hall like 75-80 easy
once the head is shaved crank arm is on a diet and upgraded spark hope to do 100mph on the salt flats once i get the money to go
oh yeah my bike shop lost sould fixies is going to be open here soon in college station TX
check out third coast fixed>com to see what we do here in the third coast
  #25 (permalink)
Old 11-06-2009, 12:17 AM
Hey I want to put a 49cc slanthead on a road bike a fuji 12 speed but keep the turned under handlebars and put the throddle and clutch handle underneath and keep the brake setup the same put a 36 or 40t sprocket and a clamshell hub 109.00 and 65.00 has anybody done this? I bet it will fly!
  #26 (permalink)
Old 11-06-2009, 12:27 AM
that all sound great i would though take a look at a shifter kit and get the drivetrain running on the right side it might serve to go faster to have between 37 and 13 teeth like a transmission and it will be less expensive than all of the parts it would require for a clutch you could just get a kit with a centirufal clutch and a pull start option. it would eliminate haveing to use a cluch and then the trhrottle would be your only concern.
  #27 (permalink)
Old 11-06-2009, 09:03 AM
That sounds good. Where can I order that, do you know and is it the same as a jack shaft?
