| | | Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work. | Is JB Weld a hole filler or a real metal replacement? Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. I hear people talking about using JB Weld to fill holes before retapping. Or bonding metals together. What is JB ...  |
08-08-2009, 06:37 PM
| | Motorized Bicycle Senior Member | | Join Date: Jun 2009 Location: Davison, Mi
| | Is JB Weld a hole filler or a real metal replacement? I hear people talking about using JB Weld to fill holes before retapping. Or bonding metals together. What is JB Weld really good for? Is it a hole filler, similar to wood putty on wood? Or is it truely a substance that bonds to metal and is as tough as metal? I used to use furnace cement to fix the burned out fire pots on old pot belly stoves. Is it similar to furnace cement?
What have you used it for? |
08-08-2009, 07:43 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Ontario
| | Re: Is JB Weld a hole filler or a real metal replacement? jb weld is not as strong as metal when used to bond to pieces of metal togeather, you can snap it with your hands, i tried it.
i remember back a couple years ago in high school tho when i took the pins out of a buddies locker hinges and jb welded them back into place with a good load in his lock. didnt get it opened up for over a week and when he finally did he bent the door all to **** haha
its good for fixin up threads thats right, and i have hered it used a couple times to repair chain smacked crankcases in dirtbikes. im not too sure if its as good as furnace cement tho, i have never hered of that.
jb weld makes wicked bombproof locktite too if you need something to never move again
<code>"isuck@code"</code> |
08-08-2009, 08:13 PM
| | Re: Is JB Weld a hole filler or a real metal replacement? Well, if anyones interested, furnace cement is unbelievably hard stuff. Don't know about its bonding limits but like I said it is good enough to seal up a completely burned out fire pot (where the hot coals are) in a furnace. Thus, the name "furnace cement". And when shaping it, a high speed grinder is barely a match for it. Takes forever to grind it. Probably comparable to the hardness of the rear sproket when I had to enlarge to hole.
Anyone ever used it? |
08-11-2009, 12:23 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: Is JB Weld a hole filler or a real metal replacement? Sounds like fun. Where can I get furnace cement?
Only Bikers know why dogs love to stick their heads out of car windows, |
08-11-2009, 01:25 PM
| | Re: Is JB Weld a hole filler or a real metal replacement? I used to buy it at the hardware store. Also called "retort cement" I think. |
08-11-2009, 02:43 PM
| | Re: Is JB Weld a hole filler or a real metal replacement? I know a lot of the guys swear by JB but I'm not a fan. If I want a true metalized epoxy based adhesive/filler I use Devcon. They make several different products specially formulated for repairs on steel, aluminum and other metals. They have some high temp stuff called 'Liquid Titanium' that I saw used successfully to reattach a broken cast iron flange on a steam boiler. I've used both,the 'Liquid Steel' and 'Liquid Aluminum' with good results. You'll pay a lot more than the hardware store JB but like they say; "You get what you pay for".
Over Youth and Skill |
08-11-2009, 02:59 PM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: Seattle
| | Re: Is JB Weld a hole filler or a real metal replacement? I can echo what others have stated and add a bit. i like devcon better but jb is good stuff. They are as hard as metal but not as tough i.e brittle. Their effectiveness has everything to do w/ surface preparation as well as application.
I've repaired gas tanks, crankcases, made molds/ fixtures for machining, tapped and machined them. They can be very useful! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:32 AM. | | | Sponsors
