| | | Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work. | Gas spills...leaky cap Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. Originally Posted by Bikeguy Joe
I used regular rattlecan Krylon with good results. Let it dry for 48 hours before ...  | |
05-22-2008, 12:24 PM
|  | Motorized Bicycle Newbie | | Join Date: May 2008
| | Re: Gas spills...leaky cap Quote:
Originally Posted by Bikeguy Joe I used regular rattlecan Krylon with good results. Let it dry for 48 hours before you get fuel on it. | One of the hobbies I had to put aside when I got into these darn bikes was RC. I've painted a few planes with Rustolem with good results, and I think hot nitromethane has got to be worse on paint than gas.
The trick was to let the paint cure before exposing it to the fuel, in the case of ROem it was two weeks. After that it was fine.
But officer, it IS only 2HP |
05-22-2008, 02:10 PM
| | Re: Gas spills...leaky cap I've painted nitro powered models with "regular paint" from a spray can with good results....the same "technique"- let the paint dry!
05-26-2008, 01:48 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Long Beach Ca
| | Re: Gas spills...leaky cap The best paint is the touch up colors for cars at the parts shop. Next is the Krylon with the high heat clear, this works well over all the paint. You will not find Rustoleum good for anything but the yard chairs. Make a gasket for your cap using leather. Have fun Dave |
05-26-2008, 03:39 AM
Originally Posted by Egor The best paint is the touch up colors for cars at the parts shop. Next is the Krylon with the high heat clear, this works well over all the paint. You will not find Rustoleum good for anything but the yard chairs. Make a gasket for your cap using leather. Have fun Dave | I agree... And it is amazing how well that "yard chair" flies!
05-26-2008, 06:37 AM
| | Re: Gas spills...leaky cap Always spray the cans upside down until the paint stops coming out when you are done painting for more than 15 minutes.
06-09-2008, 12:33 AM
|  | Motorized Bicycle Member | | Join Date: Jun 2008 Location: Baldwinsville, NY
| | Re: Gas spills...leaky cap I have had the same trobles. Thanks for all the tips. |
06-09-2008, 06:12 PM
| | Re: Gas spills...leaky cap Update:
Sprayed it, let it set two days, put it back together and rode it...
So far the engine, rattle-can-paint is holding up.
06-27-2008, 09:28 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Gas spills...leaky cap Painted mine with rattle can paint, then ratlle can clear laquer, followed by 3 coats of rolled on polyurathane out of a can/ Spilled gas on it filling tank (dumb) and no problems...I did the poly to seal the decal and make the tank smooth with decal under poly........
06-27-2008, 09:36 PM
| | Re: Gas spills...leaky cap I used Krylon flat O.D. green and no sealer coat and the gas never did anything but make some very slight, mild staining around the cap. (which actually gave the "Military Bike" more character.)
10-27-2008, 09:55 PM
| | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: austin tx
Originally Posted by RedB66 I have painted my tank about six times!!!!! I apply a two part color, silver base then a red (candy) topcoat. Followed by two coats of clear. I use the best quality rattle can I can find. Like with most things I try, I end up redoing it so many times by the time I'm done I have it mastered. My problem is with my gas cap and rough terrain. Gas leaks out of the cap. I've tried to use two rubber gaskets (no help). Anyways!! Is there a product or way that I can use to protect my paint from the gas leaking? | I usually use, engine paint. It has ceramic in it, is fuel resistant and heat resistant up to 500 degrees (silver can) or 1000 degress (gold can). If you prefer to not use any of the colors available, then be sure to a can of automotive clear coat. It will be fuel resistant too. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:24 PM. | | | Sponsors
