Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Paint Booth & Chop Shop
Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work.
Gas spills...leaky cap
Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. The high heat clear engine paint works great........Thank You....
  #11 (permalink)
Old 02-14-2008, 05:04 PM
RedB66's Avatar
Default Re: Gas spills...leaky cap
You do not need a parachute to skydive.
You only need a parachute to skydive twice.
  #12 (permalink)
Old 02-14-2008, 05:49 PM
Bikeguy Joe's Avatar
I used regular rattlecan Krylon with good results. Let it dry for 48 hours before you get fuel on it.
  #13 (permalink)
Old 03-24-2008, 05:31 PM
SMC's Avatar
SMC SMC is offline
I have the same problem. The only fix I could come up with is not to fill the tank up too much. I usually go less then 1/2.
If you value your freedom, thank a Veteran.
  #14 (permalink)
Old 03-24-2008, 05:35 PM
Pablo's Avatar
I'm pretty sure if the cap was well sealed, fuel would not flow so well.....
  #15 (permalink)
Old 03-24-2008, 06:13 PM
deacon's Avatar
minor bike philosopher
I agree with pablo, I think the air pressure pushes down on the fuel. If it were a vacuum without a return line there would be no way for the fuel to flow. Sounds logical anyway.
Me and the Ebike
New Novel in progress blog...
  #16 (permalink)
Old 03-24-2008, 06:32 PM
Pablo's Avatar
Saw it happen with my own eyes......fuel flows substantially faster with no cap.
  #17 (permalink)
Old 03-24-2008, 07:45 PM
Ilikeabikea's Avatar
So you think the Chinese made em with leaky gas caps for fuel vents? Makes sense...................
http://www.galtx.org/
http://bdconner.com
  #18 (permalink)
Old 03-24-2008, 09:07 PM
deacon's Avatar
velly tlicky those oriental devils...
Me and the Ebike
  #19 (permalink)
Old 03-29-2008, 01:25 AM
FYI: I did some research on the web conserning the problem with getting gas on your paint job on the gas tanks. Duplicolor @ Dupli-Color : Yes You Can has some very good paints and they have a two part clear coat that is oil and gas resistant. Some very good products and new type paints are on the site and there is Qtime how to video to introduce the products and give you an idea on what they do. I also remember in one thread someone ask about hi temp paint for the engine and vht for the exhaust header and muffler. The motor paint is good up to 500 degrees and the vht is good to 1200 degrees. I hope this information helps. I have five new bikes and six engines to get busy on assemling and plan on doing the fenders and gas tanks matching colors and either buff the alum. cases, or paint them with the Duplicolor engine paint or powder coat them. I come up with a simple design for the front motor mount thats strong and you dont have to drill a hole in the frame. I will post it as soon as I ground down the welds, It's been 12 years since I used my mig and the first one I welded is not as smooth and clean as it should be. I just got back in to bikes after a 45 plus year lay off working with cycles & scooters. I'm really motivated after seeing all of the members bikes and great ideas.
David
  #20 (permalink)
Old 03-29-2008, 07:13 AM
deacon's Avatar
I painted my tank with craft paint lousy job but I clear coated it for with paint from the autostore/ the clear coat went on three of four times and I have not had a mark since. I think I would paint it with anything again then hit it with three or four coats of auto store clear coat.
Me and the Ebike
