Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Paint Booth & Chop Shop
Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work.
Body mounts
Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. I finally got the Lexan that I was after for the bodywork last week so I figured today was a ...
Old 05-10-2009, 06:06 PM
Rockenstein's Avatar
Lightbulb Body mounts
I finally got the Lexan that I was after for the bodywork last week so I figured today was a good day to get started on the mounts. In total I have 8 mounts to braze on in various locations and that part I'm hoping will go smoothly...the hardest thing so far was stripping the paint so I have a clean surface to work with.
Wish me luck
I refuse to be taken apart...
Old 05-10-2009, 10:35 PM
2door's Avatar
Default Re: Body mounts
This is interesting. I'm going to be watching the progress and waiting for the results. Keep us posted, Rock.
Over Youth and Skill
Old 05-10-2009, 11:43 PM
Well I've got the 5 main mounts brazed on...they didn't turn out so bad I guess considering I suck with a torch and cut the strips with a pair of surplus store snips Still need a few more mounting points but I'm holding off on them for the night as I want to put the motor back in and double check my mounting locations on the seat tube and down near the bottom bracket.
The picture shows the left side panel template roughly in the position I have in mind Tom. For the top I'm undecided if I should make it square or form it with a heat gun over a 2" pipe so as to have a nice radius. I would have liked to make the whole thing a one piece unit but I was not certain I could form it properly and didn't want to risk ruining 60 bucks worth of lexan...so 3 pieces it is. On the front I'm thinking a small bit of lexan wrapping around the head tube will do the trick and look proper. The lower area along the length of the down tube and up the back side of the seat tube will be left open...this should give me enough airflow to keep things cool.
Old 05-11-2009, 10:06 AM
2door's Avatar
Rock,
You probably know this but just in case...if you use a heat gun to form the Lexan remove the protective paper before heating. If not it will stick and it's a bear to get it off afterward. I've done some Lexan work and it will form nice but the trick is to get enough heat without warping. The heat needs to be applied over a large area with a big nozzled heat gun or the bend will not be consistant throughout its length. My crew and I did some machine guards a couple of years ago and they came out neat but we trashed a few square feet of the plastic before we found out how to do it right. Its expensive stuff and unless you feel confident you might want to stick with piecing it instead of trying to form it in one part. Just advice based on experience. Good luck, keep us posted.
Old 05-18-2009, 09:31 PM
Cabinfever1977's Avatar
if i was to make some side covers id use some metal vent covers,there cheap and easy to mount and work with plus they are air vents.they come in many diffrent sizes and are very cheap.
Old 05-23-2009, 07:42 PM
i would guess its a china girl,one wouldnt need to cover up a electric bike.
Old 06-01-2009, 10:52 AM
Cool project keep us updated!
www.firebellycycles.com
Visit me and my bikes at Sports X in Seattle, WA
1978 Vespa Grande, 1977 Mobylette 50L, 1980 Garelli VIP, 1959 Tote Gote Model B, 1961 Tule Trooper, 1963 Homelite Trail King, 1980 Yamaha XJ650
1985 Schwinn Sierra with 67cc/SBP Shift Kit/Pipe
Old 06-01-2009, 10:55 AM
Norman's Avatar
LORD VADER Moderator
you know you can bend lexan in a metal brake just like sheet metal.
Norman
norms-iron-works.tripod.com
  #9 (permalink)
Old 06-01-2009, 09:10 PM
goat herder's Avatar
I new lexan was forgiving, as apposed to plain old plexi. thats cool to know a metal break works on these. Thanks Norm
One can do anything you set there mind to.... Do a good thing...
