Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Paint Booth & Chop Shop
Paint Booth & Chop Shop What really makes a motorized bicycle stand out is the customized work and paint jobs we give them. We'd love to hear your ideas and have a look at your customized work.
Bicycle engine Paint
Discussion at Motorized Bicycle Engine Kit Forum in the Paint Booth & Chop Shop forum. Has anyone painted the engine? I live on the water and the salt air seems to rust everything, so I ...
Old 02-29-2008, 06:08 AM
Motor Bicycle Apprentice
Default Bicycle engine Paint
Has anyone painted the engine? I live on the water and the salt air seems to rust everything, so I would like to try to protect it with a high temp paint.
Old 02-29-2008, 07:17 AM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Engine Paint
i have talked to numurous people that have painted thier engine. they say to use bbq grill paint to paint your bicycle engine and it works like a charm. welcome to the forum troy glad to have you with us
http://stockmarketcats.com/
Old 02-29-2008, 08:42 AM
Norman's Avatar
LORD VADER Moderator
Yes, you can paint it any color. I like the bare finish as if it leaks any nasties, a can of brake clean will make good as new again. If you want it to look like a Honda gold wing engine a nice aluminum color use this.
Dupli-color DSGM347 Medium Gray Metallic. At least that is what I remember when I had a gold wing and used carb cleaner and found out the aluminum parts were painted. I think you can powder coat the engine as well. There is a lot of discussion on what's the best for keeping it cool. Black is what comes to mind but this will open up a can of worms as others will not agree. I'd say do what you like and to heck with what others say its your engine you can treat how you want to. During the world war 2 the Harleys that went into the service were painted all olive drab all of it, engine included. The guy in Mo. who races chain saws, yea they really do. Said he knocks off all the cooling fins on the flywheel so the engine will get good and hot he said it will make it seal better on the rings. But the life of his engines are short and I did say fins on the flywheel and not the cylinder. He also removes any base gasket to bump up compression and advances the timing and does the spark plug mod I showed you all, along with other things to make the saw really rip for a little while.
Well if I had a sand blasting cabinet I'd try blasting all the outside and leaving it at that. more surface area equals better heat dissipation. My opinion only.
Black wrinkle on the cylinder with red wrinkle on the head would look sharp and then polish the case covers and maybe the case but that's too much work for me. My motto, chrome won't get you home but it might get you l88ed. If that is naughty Mod. do your duty. I apologize.
So what color you thinking of?
Norman
norms-iron-works.tripod.com
Old 02-29-2008, 09:19 AM
CRUISER's Avatar
ADMINISTRATOR
i couldn't have said it better myself norman
Old 02-29-2008, 12:37 PM
RedB66's Avatar
I have used Dupli-Color Engine Enamel with very good results. I used the flat black. They have about seven different colors. You can also use a good quality rattle can paint (any color) and cover with a clear coat of engine enamel to protect if from the gas and oil.
Old 03-01-2008, 06:09 AM
Bikeguy Joe's Avatar
Clean it with brake or carb cleaner first.
Sand the chrome on the exhaust with some 220 paper until there is NO SHINE, if you are apinting the exhaust.
I used Krylon with no primer and it worked great.
The exhaust will only burn off from the flange to about 6" down the pipe if you decide to paint the exhaust.
Let it dry for 24 hours and you shouldn't have any problems with fuel or oil removing the finish- in fact, my gas cap always leaked and the worst that happened was a stain would start on the tank, but could be wiped off.
The paint stayed.
Old 03-01-2008, 10:57 AM
Easy Rider's Avatar
Default Re: Bicycle engine Paint
VHT hi temp paint is pretty good stuff. I've used it on my exhaust systems (from car headers to expasion chambers) and it retains the gloss. Plus it comes in lots of different colors. You can usually get it at any auto store.
Old 03-04-2008, 05:06 PM
w31john's Avatar
if you need flat black, i use BBQ paint on my exhaust from a rattle can. that works good for me
  #9 (permalink)
Old 03-07-2008, 07:17 PM
BBQ Black- not flat, not gloss, just right!
  #10 (permalink)
Old 03-07-2008, 09:04 PM
Norman's Avatar
I like black.
Similar Threads
Texas law for engine assisted bicycle Norman Laws and Legislation 45 08-06-2008 07:37 PM
custom paint bicycle CRUISER Paint Booth & Chop Shop 6 08-05-2008 02:01 PM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
Sprocket Installation - Bicycle Engine Kit CRUISER Motorized Bicycle General Discussion 13 01-29-2008 05:54 PM
Motorized Bicycle Engine Oil - 2 cycle Pre Mix Pablo Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 0 12-29-2007 03:38 PM
