Motorized Bicycle ContestCome and enter one of our Motorized Bicycle Contests.
summer build donner bikes PICTURES
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Contest forum. this is an old bike i picked up at the junk yard and to answere the question YES IT WORKS ...
this is an old bike i picked up at the junk yard and to answere the question YES IT WORKS i couldnt belive it but i turned the crank and it lit up
btw this bike cost 3$
i would pay double that for the light!
the part of the frame that holds the rear tire is bent but im only using the front tire, pedal assembly and crank, handlebars, light and seat post
and this is the bike im using the seat , forks, rear tire, brakes, frame patern, the clamp that holds the handle bars and bolts from (the bolts have the brand symbol on them
Please show pictures as you progress. We just ordered an 80 kit for my wife, and she wants to use a girls bike. She has arthritis in her hip and doesen't want to have to lift her leg any higher than she has to, to get on it.
I have been seeing a lot of kit tanks mounted on luggage racks behind the seat. I'd go that way. Yes you can do a womens bike, I did a 24" one and it was a lot of fun but it was also small.
I even dropped a twenty inch wheel on the back to make it even lower for me. If you check the bike only section you will see a bit about bikes for an old man (me) there are some simple inexpensive changes we can make to help with the stiff legs and bad balance.
i think i decided to run a chain drive rack mount 4 cycle from ebay. im just trying to figure out a way to make it look old. mabie fade the plastic and paint the motor all splotchy
