| Sponsors
| | | | Motorized Bicycle Contest Come and enter one of our Motorized Bicycle Contests. | summer build donner bikes PICTURES Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Contest forum. Zim, sand your frame down, spray it with salt water, let set for a week or so spraying occasionally, after ...  | |
06-05-2008, 12:13 AM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: summer build donner bikes PICTURES Zim, sand your frame down, spray it with salt water, let set for a week or so spraying occasionally, after the desired patina is achived, spray a clear coat over it. For more tips on antiqueing bikes check out ratrodbikes.com • Index page , theres some really cool stuff there...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
06-05-2008, 05:14 AM
| | Senior Motorized Bicycle Builder | | Join Date: May 2008
| | Re: summer build donner bikes PICTURES frame will be bamboo
im refering to the actuall motor |
06-05-2008, 08:40 AM
| | Re: summer build donner bikes PICTURES Paint it grey.
09-20-2008, 10:14 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Sep 2008
| | Re: summer build donner bikes PICTURES 3 speed sturmey archer rear end |
09-21-2008, 05:23 PM
| | Re: summer build donner bikes PICTURES For the arthritic lady let me suggest
a girly bike 26" then get yourself a child's 20". Swap the rear wheel and the crank over to the girly bike. That is the only kind i have now except for the china bike and It used to be that way. Still don't know why I changed it. |
11-20-2008, 12:50 PM
|  | Motorized Bicycle Apprentice | | Join Date: Nov 2008 Location: oak cliff tx
| | Re: summer build donner bikes PICTURES I had problems with the sturmey 3 speed hub, it's too big for the drive sprocket's bolt pattern.
-Ben |
11-20-2008, 02:16 PM
|  | The Old Master Motorized Bicycle Builder | | Join Date: Oct 2008 Location: SETexas
| | Re: summer build donner bikes PICTURES Quote:
Originally Posted by bdavanza I had problems with the sturmey 3 speed hub, it's too big for the drive sprocket's bolt pattern.
-Ben | Why would you have to change drive sprockets on the hub? If it is too wide, you can allow for that when you build the frame. If you are trying to mount it to the existing frame, you can carefully widen the rear triangle of the bike. Instructions for doing so are available.
If you decide you can't use the S-A would you consider selling it?
Ted
I wasn't born in Texas but I got
back here as soon as I could.
Help support the forum. Donate today.
11-20-2008, 03:02 PM
| | Re: summer build donner bikes PICTURES My problem is related to the hub being too fat for the bolt pattern of the sprocket. A different sprocket would solve this but I'm going to swap for a coaster brake hub. Even the rubber gaskets for my sprocket don't wrap around the S/A hub, take a look at this pic. I can't even get 3 of the bolts through, they align with the spokes right where they overlap. I will be keeping it, though.
-Ben |
11-20-2008, 03:30 PM
| | Re: summer build donner bikes PICTURES Ah so. Gotcha covered.
You will just need to contact Andyinchville. I think he has an extra sprocket or two that might fit. Take a look here: Misc Sprockets For Sale.
I would keep it, too.
Ted
11-20-2008, 03:35 PM
| | Re: summer build donner bikes PICTURES Your bamboo bike might benefit from one of Pablo's shifter kits. One thing it does is replace the rear mount with much more support. You can use the S-A, too. And shift it.
I just ordered one.
Ted
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:45 AM. | | |
