| Sponsors
| | | | | Motorized Bicycle Contest Come and enter one of our Motorized Bicycle Contests. | Just finished, grocery getter! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Contest forum. I am having hard time with picture downloads. So i hopefully attached pictures. Clueless to this system. Anyway. this is ...  | |
06-15-2008, 07:10 AM
|  | Motorized Bicycle Builder | | Join Date: Jun 2008
| | Just finished, grocery getter! I am having hard time with picture downloads. So i hopefully attached pictures. Clueless to this system. Anyway. this is a 1980 schwinn cruiser frame. stock bottom crank and bearings, cheepo springer front end in good shape that I got with bike, nexus 3 speed hub with electra rims and flame pattern tires. Custom cut front and rear schwinn fenders. Custom made delron motor mounts. I sand blasted parts before shooting mars red auto paint. New bars, seat, basket, and hub shifter. 80cc motor kit. added shims on both sides of rear hub to help chain clear frame. replaced mounting studs with hardened. Am toying with 1.5v led lights in parallel for tail and running lights with 6v r/c car battery under seat to back up charging system. Not sure if i can hook up battery direct without it getting overcharged. Hey, if by seat gets hot, I guess i will figure it out.
If your not sure, ask a friend first!
06-15-2008, 07:33 AM
| | Senior Motorized Bicycle Builder | | Join Date: May 2008 Location: Long Island, New York
| | Re: Just finished, grocery getter! Very nice build! Welcome, these forums are great with lots of information and good people.
I do have a question, what are these delron motor mounts? Do they protect the frame and/or reduce vibration? Any more info would be great! |
06-15-2008, 07:54 AM
| | Re: Just finished, grocery getter! Delron is like nylon, but harder. Its what the gears in a lot of cordless drills are made of. I got a 1 inch by 10 by 20inch sheet of it from when i worked in robottics. I cut a 1 by 1 1/4 strip. then cut two pieces and drilled them for studs. I needed more clearance from sprocket. I groved front mount to fit frame tube. added longer hardened studs. then drilled and tapped long 1/4 inch bolt thrue rear clamp, and tapped it into rear alloy mount for more support. replaced nuts with hardened, and doubled up on them. The delron wont reduce that much vibration, but hopefully enough to save studs and frame welds.
If your not sure, ask a friend first!   |
06-15-2008, 08:46 AM
| | Re: Just finished, grocery getter! I love your bike. The basket is tied down very well and since i lost my hangon basket and almost ran over it when it jumped off I salute you. Be sure you tie down you packages well. Any big bump and they will be all over the road.
You did a great job on the bike. |
06-15-2008, 09:30 AM
| | Re: Just finished, grocery getter! Ahhh ok..so it's similar material to the tools used in PDR to tap down high spots.
I have an upcoming project for my g/f's fathers ratfink bike and he wants it done PERFECTLY. I don't blame him, but I figure I can use this so I don't scratch the frame. Where can I pick this stuff up from and how m uch does it cost? |
06-15-2008, 10:42 AM
| | Re: Just finished, grocery getter! Quote:
Originally Posted by tinkerfinger Delron is like nylon, but harder. . | Oh you mean Delrin. Polyoxymethylene plastic - Wikipedia, the free encyclopedia
Good idea! |
06-15-2008, 06:37 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: Just finished, grocery getter! HELLO TO ALL YOU PEOPLE.. I DON`T SEE MUCH ON HERE ABOUT FRICTION DRIVES !!  WHAT DO SOME OF YOU THINK OF THEM. WHEN 11 YRS OLD (1950) A NABOR HELPED ME BUILD A 3/4 HP BS POWERED MOTOR BIKE W/O PEDDLES. I`AM HOPING TO SELL SOME KITS LOCALLY. HAVE YOU SEEN THE VIDEOS (jb1970ny) ?? LATER, RON..  |
06-15-2008, 07:28 PM
| | Re: Just finished, grocery getter! I might be the only one here that actually thinks friction drives are superior to chain and sprocket or even belt and pully drive.
If you have a good kit or good system to add friction drive to an engine let me know. I think A friction drive with a good clutch type engine would be ideal.
You probably should start a thread though to get maximum coverage for your discussion. |
08-02-2008, 07:27 PM
| | Senior Motorized Bicycle Builder | | Join Date: Jul 2008
| | Re: Just finished, grocery getter! And if you lose your job because of all the time you spend on your bike, you can always get a paper route.
ricland |
08-02-2008, 08:58 PM
| | Re: Just finished, grocery getter! TINKERFINGER YOUR GROCERY GETTER IS SUPER NEAT. I CAN ONLY IMAGINE HOW MANY HEADS IT HAS TURNED.  BACK ON JUNE 15, THAT WAS MY FIRST DAY ON THE FORUM ! SORRY ABOUT MY POST BACK THEN. I HOPE IT DIDN`T MESS UP YOUR THREAD. I RENTED A ROOM FROM A ELDERLY WOMAN MANY YEARS AGO, AS SHE WOULD SAY; ITS SWELL ELEGANT !! (YOUR BIKE) . HOW HAS IT BEEN RUNNING?  LATER RON
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:39 AM. | | |
