| | Deacon's Bike Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Contest forum. here at least is the picture of the clown bike. It at least turned out as gawdy as I planned ...  | |
04-12-2008, 02:04 PM
| | Re: Deacon's Bike here at least is the picture of the clown bike. It at least turned out as gawdy as I planned lol
It's supposed to be a junkyard build... how much more junky than this can one get... Too bad I couldn't get the motor to work on it. Actually I had the motor working till I screwed it up all by myself.
04-12-2008, 05:39 PM
| | Re: Deacon's Bike One of the members here (big joe) sent me an engine just like the one I ruined this morning. As luck would have it, it arrived just as I finished tearing down the ruined engine. Someone had worked on is engine and told him it had low compression. I started it in two minutes but it would not keep running, so I switched out the carb for one I knew worked. Took a little more work to seal off the gasket ect but it runs like a dream. Better than the original engine I ruined (of course I would say that)
Tomorrow I need to do a few things to it and then its ready to mount. I am still having second thoughts about this build but we shall see. At least the drive wheels are ready and don't need any adjusting on the engine. Not that I would ever tap a drive shaft again regardless of the need. |
04-12-2008, 06:27 PM
| | Re: Deacon's Bike How did you ruin the old one? I think I missed something.
04-12-2008, 09:35 PM
| | Re: Deacon's Bike I was trying to add some size to the foot peg drive wheel. I "persuaded" a cover to go onto the peg. In doing so I managed to drive the drive shaft back and lock it up.. I got a lot of good parts off it though. If I do go forward with the friction drive conversions I can alwys use the parts. The whole top end it good, the carb is already on big joe's engine. The jug is here and the magneto ect. There really isnt much to these little engines. |
04-13-2008, 06:57 AM
| | Re: Deacon's Bike It's all about the learning isn't it?
04-13-2008, 10:20 AM
| | Re: Deacon's Bike nothing like a lesson that cost you fifty bucks lol I sure as heck remember those. |
04-13-2008, 10:24 AM
| | Re: Deacon's Bike I got the new old engine mounted, the drive wheel. I am not working on the throttle. It looks as though the simplest thing well be to go back to the hardwire lawn mower cable. the bike cable won't return the carb control and a spring just isnt dependable. It going ot be cold the next couple of days anyway. So I have excuse to work on the bike. I'm going to do my basic research on the lawn mower cable now. |
04-13-2008, 01:57 PM
| | Re: Deacon's Bike For not this project is a bust. I can't get the drive wheel tight enough to drag start or to push the rear tire. It has to do with supporting the free side of the friction drive. I have everything else ready, just have to figure out a drive assembly that works. With a wheel supported on just one side the motor just moves down at a screwy angle it doesn't get tight on the wheel..
Ive got an idea all of a sudden. Since that peg has a mountain bike axle thread on the side away from the engine I guess I need to get a mtb wheel assemby. screw the axle into the peg, then use the bearings and assembly to anchor the off motor side of the drive. Sounds complicated I might just keep thinking on this. I have the bike and a working motor it's just a matter of time before I figure it out. Too bad norman or joe isnt around to figure it out for me. |
04-13-2008, 02:02 PM
| | Re: Deacon's Bike how do you make a brass bushing. that in a flat bar would do to hold the off motor side of the drive wheel in place. |
04-14-2008, 08:04 AM
| | Re: Deacon's Bike You can buy ready made bushings at Home Depot or Lowe's.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Deacon's bike build | deacon | Pre-Motorized Bicycle Information. | 39 | 06-27-2008 11:11 PM | All times are GMT -5. The time now is 02:06 AM. |
