Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap And Shop
Searching for wheel spoke mounted 55 tooth sprocket
Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. Hello forum members, I am looking for a good used or NOS 55 tooth sprocket that bolts to the(with ...
Old 05-24-2008, 12:09 PM
Motorized Bicycle Apprentice
Question Searching for wheel spoke mounted 55 tooth sprocket
I am looking for a good used or NOS 55 tooth sprocket that bolts to the(with adapter) to the spokes of the rear wheel;I will consider either steel or aluminum,but prefer steel sprocket.
TRhe reason I need this tooth count is because I will be using a Comet TAV2-30 cvt that has an overdrive built in!!
Old 05-24-2008, 06:17 PM
Default Re: Searching for wheel spoke mounted 55 tooth sprocket
Both of the vendors to the left!!
Old 05-25-2008, 03:41 AM
Thanks for the reply,misteright1.
I have done business with dax before,but need a larger sprocket that I found is out of stock on thatsdax website;There is another one I found through google that has the sprocket I need
and has it in stock,so I will probably order it after the holiday weekend!
Last edited by robo5050 : 05-25-2008 at 03:47 AM. Reason: wireless microsoft keyboard errors
Old 06-18-2008, 09:50 PM
Mopedamauter79's Avatar
I have a larger teeth sprocket lying around. I can check to see how many teeth it has.
Advertisers
