| Sponsors
| | | | Swap And Shop Use this forum to buy, sell or trade your motorized bicycle items. | need the plastic wheel for idler Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. my idler roller stripped out. does anyone have one laying around and would want to sell it? the plastic roller ...  | |
07-17-2008, 08:42 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Jun 2008
| | need the plastic wheel for idler my idler roller stripped out. does anyone have one laying around and would want to sell it? the plastic roller is all i need.
jeff
__________________ Big Boss Hoss
My "happy time" engine is so damn happy I heard it giggle at me today |
07-17-2008, 09:04 PM
| | Re: need the plastic wheel for idler also i need the stud that goes thru it sorry. jeff
07-17-2008, 09:10 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: north bend wa.
| | Re: need the plastic wheel for idler head for the hardware store |
07-18-2008, 12:17 AM
| | Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Maine
| | Re: need the plastic wheel for idler Looks like thatsdax.com has it in stock..ball bearing with the mounting stud for 11.99 plus shipping. You might be better off to buy two and get free shipping. I'm pretty sure u could sell the extra one with no problem. Page Title |
07-18-2008, 07:43 AM
| | Re: need the plastic wheel for idler ...or try to make one from some hardware and a skateboard wheel.
07-18-2008, 12:48 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Decatur,IL
| | Re: need the plastic wheel for idler someone near you or someone you know has a old skateboard laying around or visit your local roller rink for a old wheel. put a stud through the wheel and chuck it in a drill press and use a old screwdriver to lathe the center of the wheel ( to make a channel about 3/8"-1/2" deep.
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
07-18-2008, 02:52 PM
| | Re: need the plastic wheel for idler You don't even need a channel in it, just the roller will work fine.
07-18-2008, 03:02 PM
| | Re: need the plastic wheel for idler the skateboard wheel needs a channel or the chain will fall off , it is also a guide for the rear sprocket ; to keep the chain from climbing the rear sprocket!
Reason: more detail
07-18-2008, 03:05 PM
| | Re: need the plastic wheel for idler If the skateboard wheel is lined up with a straight chain run, no groove is needed as the tensioner only acts as a tensioner, not a chain guide.
07-18-2008, 03:06 PM
| | Re: need the plastic wheel for idler P.S., I usually run my chains on the loose side and never had a problem with the chain climbing the sprocket.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:40 AM. | | |
