| Sponsors
| | | | | Swap And Shop Use this forum to buy, sell or trade your motorized bicycle items. | Looking for part Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. I am looking for a chain tensioning wheel. I need another one so I can keep the chain away from ...  | |
06-11-2008, 09:34 PM
|  | Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Baldwinsville, NY
| | Looking for part I am looking for a chain tensioning wheel. I need another one so I can keep the chain away from the frame in one spot. The chain has removed some of the tubing. I can fill that in, and I want to keep the chain away from that area. |
06-11-2008, 10:49 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Looking for part Vendor to the left sells them.......
06-12-2008, 06:25 AM
| | Re: Looking for part They show up on ebay from time to time as well... I have one but it is toast... In my opinion all of them are accidents looking to happen. |
06-12-2008, 08:21 AM
| | Re: Looking for part Have you considered using your ability to "create" and make one with some simple parts available anywhere? Skateboard wheel, metal stock from Tractor Supply or Home Depot, ect?
06-12-2008, 10:38 AM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Decatur,IL
| | Re: Looking for part before you put a tensioner on , why did it rub a hole in your frame the first time? and is it going to happen again with a tensioner?
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
06-12-2008, 10:09 PM
| | Re: Looking for part |
06-13-2008, 08:19 AM
| | Re: Looking for part Quote: |
| I can repair the frame. With the chain tensioner I can keep them apart and from happening again.
Thanks for the tip about tractor supply. |
06-13-2008, 11:57 AM
| | Re: Looking for part With a tensioner the chain is sitting higher, that is why the chain will not rub. On my first bike I did not use the tensioner because I was able to put washers on the rear wheel shaft which spread open my bike frame enough to clear the frame for the chain.
You could also see if flipping the rear sprocket so that the chain runs closer to the rear wheel may help, or even leaving the rubber off of the outside of the sprocket may help.
From what I have seen, every bike and rear wheel is different and it could be just a matter of spending days and days screwing around until things work out for you.
If you look around you may notice that a lot of belt driven machines use what may be called an idler and they have bearings. It could be as simple as replacing the ones that come with the bike kits with one of these off of a snow blower of garden tractor. |
06-13-2008, 01:00 PM
| | Re: Looking for part Don't leave the rubber off any part of the sprocket, it will ruin your spokes.
Make sure the chain run is straight as possible, with no offset.
06-13-2008, 07:19 PM
| The sprocket is already running withe the chain inward. I have 2 washers on that side to keep the sprocket from rubbing on the frame as well. I have an alloy wheel that the sprocket bolts into instead of the disk break. The chain was rubbing the frame at the top of the sprocket a little away from the sprocket becouse of the side to side movement. I purchesed the chain tightener from tractor supply and it will work nicely. thanks for all the help. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:29 AM. | | |
