Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap And Shop
Looking for lower case housings
Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. The woodruff key rattled out on a friends bike and knocked a hole in the flange on clutch side of ...
Old 12-12-2008, 02:32 PM
Default Looking for lower case housings
The woodruff key rattled out on a friends bike and knocked a hole in the flange on clutch side of his motor. The vendor he got his kit from is not willing to fix the issue.
Attached is a couple of pics. Damage was caused by a galled screw thread on the crankshaft pinion that did not tighten up properly and allowed the pinion (sometimes called bevel gear) to float and the woodruff key to come loose.
Does anyone know a vendor with the lower unit in stock?
Thanks!
James
looking-lower-case-housings-damaged-case.jpg  looking-lower-case-housings-damaged-screw.jpg
Old 12-12-2008, 02:54 PM
jasonh's Avatar
Default Re: Looking for lower case housings
Is there any other damage besides the missing key and that hole? You should be able to find a new key, and the hole is really only cosmetic....
I haven't seen any lowers for sale, you'll probably just have to buy the whole motor (sans kit). I think you can get one for like 90 bucks from thatsdax.
Old 12-12-2008, 03:04 PM
I have already replaced the key. I thought that the clutch ran wet on these motors? I was scared to induce an air leak into the motor.
Turns out the vendor might be somewhat helpful when it comes to getting me parts. We shall see. Waiting for a reply back from him.
Old 12-12-2008, 03:08 PM
jasonh's Avatar
Nope, it's a dry clutch.
Old 12-12-2008, 03:44 PM
MotorbikeMike's Avatar
Dealer
Hi what size engine is that? I may have a case that would fit
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 12-12-2008, 04:06 PM
It is a 80cc (69cc) motor. That is if it is what the vendor said it was.
Thanks!
Old 12-12-2008, 05:29 PM
Dealer
Unlikely I would have any of those. When i got started in this, the 48cc squarehead was the ONLY engine available. Then the Roundhead 48, North China "80" and MUCH later the so-called 80 from South china (called 68, 69, 70, and 80cc).
Good luck amigo, MANY people blew those up and should have cases for you.
Mike
Old 12-13-2008, 05:41 PM
i do have the cases your looking at $50.00 for the complete lower end i have 2 of the lowers in stock now
