Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap And Shop
lights using the white wire that really work
Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. I found an 1895 lamp housing. I wired it with a single 6volt 15amp bulb and a small toggle switch, ...
  #21 (permalink)
Old 06-24-2008, 12:55 AM
tinkerfinger's Avatar
Motorized Bicycle Builder
Default Re: lights using the white wire that really work
I found an 1895 lamp housing. I wired it with a single 6volt 15amp bulb and a small toggle switch, both from radio shack. works well. the convex lense is 2 1/2 dia and 3/4 thick. The glass side jewels look cool at night.
  #22 (permalink)
Old 06-30-2008, 08:31 AM
Pablo's Avatar
Norman - Crazy question (I'm at work right now) - how many volt is the bulb in the small light?
Thanks,
Paul
  #23 (permalink)
Old 07-02-2008, 06:46 PM
Norman's Avatar
LORD VADER Moderator
either size light will work on 6 volts dc or the white wire. Both lights have the same bulb the reflector is bigger on the big light.
norms-iron-works.tripod.com
  #24 (permalink)
Old 07-02-2008, 10:10 PM
Pablo's Avatar
Right on - thanks!
  #25 (permalink)
Old 07-03-2008, 02:15 AM
Motorized Bicycle Apprentice
Strap on a mini alternator and a battery.
I replaced many magnetos because people used the white wire.
It kills the magneto alot faster if you are using a bulb with a lot of current/volts.
The white wire is only giving out 5/6 volts.
Try using bright leds. I had a set up on my cruiser and it worked like a charm.
  #26 (permalink)
Old 07-03-2008, 03:08 AM
Has anybody had any luck with old 6v motorcycle headlamp bulbs. I found an old harley bulb thats dual element 18/18 watts on ebay. Is the element just too big? Any thoughts
  #27 (permalink)
Old 07-03-2008, 10:41 AM
Norman's Avatar
The Harley bulb is too big.
Harp
you might be right but I've been running my lights for a year now and NO blown ignition systems so maybe you are blowing a little smoke? Same bulb just different housings on my bikes. My bulbs have not caused a problem as far as I know on anyone's bike. Anyone that is using my lights that have a problem put your response on here so I can clear this up.
Norman
  #28 (permalink)
Old 07-03-2008, 10:49 AM
Bikeguy Joe's Avatar
Genius Visionary
The mag will not be affected by using the white wire to power a light.
  #29 (permalink)
Old 07-03-2008, 12:10 PM
CRUISER's Avatar
ADMINISTRATOR
i put hundreds of miles on my bike with norms light and had absolutly no problems. i used it for work and alot of the miles were after dark and it was brighter and better then any led you could purchase and you dont have the added wieght and battery's to purchase. i used to run 2 led high intensity battery lights and one of normans lights was 3 times as bright as the 2 togather. it was like having a regular head light on the front of the bike
http://stockmarketcats.com/
  #30 (permalink)
Old 07-03-2008, 05:31 PM
Wow everyone, I Clearly said that I have not seen Norman's light, And that I have heard good things. If you want to call that blowing smoke, Be my guest. I Only tried to clearly state my own opinion on this website. Last I checked, thats what it was for.. As far as my statement of being worried about useing the white wire for fear of killing the mag, I based my opinion in the threads I have read on THIS WEBSITE. There are riders out there who have posted this info on this wesite, And I read it... What do you expect from a consumer,,
If this is a site for people to learn, share info, and help support the sport, Then telling someone their blowing smoke tells me what they are trying to support, their product..
I Only mentioned Norm's light in an attempt to exclude it from my statement. Not to bad mouth it.. As I said the first time, I have not seen Norm's light, but I have heard good things.
By the way, I formed that opinion from the info on this site too.
Advertisers
