Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Swap Shop
Lighting Problem Solved .
Discussion at Motorized Bicycle Engine Kit Forum in the Swap Shop forum. This is part of an eBay ad . The person is selling complete motorised bicycles . This is part of a listing . ...
Old 05-14-2008, 02:46 PM
D.J.'s Avatar
Default Lighting Problem Solved .
mightywonderful( 381)
The Superlight System for Motorized Bicycles (coming soon!).
We are proud to announce the introduction of a "SUPERLIGHT SYSTEM" now in development for all motorized bicycles with 2 cycle China made engines. This product has been undergoing test for the past 2 years (on and off). A very promising solution has finally been discovered and tested during the past 3 months.
What is The Superlight System About?
The "Superlight System" is about being able to ride your motorized bike at nights using your lights and not being concerned about having to recharge batteries. This system will feature a recharge mini SLA 6 volt battery that will be directly recharged from the bike's engine.
Many owners of these motorized bikes have tried running lights off the engine using the white wire, but this is not a very reliable type of lighting. The current from the white wire will only support up to about 250mA (or 1.5 watts) for the headlight. This in itself is not much light.
Anything over a certain amount of current draw on the engine's white wire will cause the bike to experience hard start or no start. A CDI (ignition coil) that's not in excellent condition, or within a certain tolerance could aggravate this problem even more.
Features Included The SUPERLIGHT will mainly consist of a SLA rechargeable battery, a weatherproof battery case which mounts behind the seatpost, a replaceable mini circuit board, a circuit protection fuse inside the battery casing, wires with terminals to connect to ground & engine, and a light switch (mounted on upper frame rail).
This system to designed to support swrewbase headlamps with 3w (500mA) bulbs or higher,in additiion to tail light. It's designed to work with common 6v generator lighting systems, which normally come with 250mA bulbs, but you can replace them with 500mA, which is the maximum common amperage available for screwbase bulbs.
The rechargeable "Superlight System" will be available with and without lights, to suit those who already have generator bicycle lights. This system will not recharge from bicycle generator, but from motorized bike engines. A separate system is also being developed for regular bicycles with generator.
Battery will recharge from 65% capacity to full charge in about 2 to 3 hours with lights off, and remain charged up with lights on. A 1.2 amp SLA battery will run lights for 2 hours without going dim (with engine off).
If battery happens to go weak with lights on, engine will still support a bright enough light for a safe ride, without any major strain on the ignition system.
Coming Soon!
Old 05-14-2008, 06:46 PM
Bikeguy Joe's Avatar
Default Re: Lighting Problem Solved .
Well, Norman's white wire light works pretty good (strat the bicycle motor and warm it up, then hit the switch) and so do any number of rechargeable battery/lights. Both are cheap and easy to install.
Not sure how this system is any better.
Old 05-16-2008, 03:10 AM
Motorized Bicycle Apprentice
or just use the lights off one of those wheel generator kits
Old 05-17-2008, 08:12 PM
Norman's Avatar
LORD VADER Moderator
Gee I thought I'd solved the lighting problem a long time ago. I even told everyone how to make the lights work of the white wire with headlight and taillight posts and pictures on a different forum then I got banned form there partly because of that and mostly for my web site having the other forum listed below this forum which I think is a very good reason to ban someone . They still don't believe the lights will work off the white wire I even have gotten emails from people saying that my lights will not work but how could they know they never bought one of my lights.
so you solved the lighting problem good luck on thinking that.
norms-iron-works.tripod.com
Old 05-17-2008, 08:37 PM
I couldn't find that on ebay....
Normans patented white wire light is more than adequate for me.
Old 05-19-2008, 01:46 PM
D.J.'s Avatar
Default Re: Lighting Problem Solved ?
It is still on eBay .
eBay Store - WONDERFUL CREATIONS STORE: Coming Features
The advantage as I see it is that the battery should never need an external charge . The motor will charge the battery when the light is off and the battery power adds to the brightness of the light when the motor is running . The light can also be used when the motor is off . I am not putting any-one's system down and I have no relation to the seller . I am glad there are people still working and trying to improve our hobby/addiction including Norman and these people .. .... D.J.
Similar Threads
Bicycle lighting??? SJCASEY1110 Motorized Bicycle General Discussion 2 04-05-2008 10:08 AM
Solved this whole chain tensioner thingy jhey Motorized Bicycle General Discussion 12 02-24-2008 04:35 PM
OVERSIZED TUBING solved wayde Mounting Techniques 13 02-01-2008 12:44 PM
Motorized bicycle OVERSIZED TUBING solved wayde Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 4 02-01-2008 12:44 PM
Sprocket Problem Joshboy Bicycle Engine Kits 4 01-05-2008 04:15 PM
