| | | Swap Shop Use this forum to buy, sell or trade your motorized bicycle items. | Help!!! I Need A Part!! Discussion at Motorized Bicycle Engine Kit Forum in the Swap Shop forum. Dag Nabbit. Wouldn't ya know it? I just bought one of those 80cc two stroke jobbies, got it all ...  | |
06-23-2008, 04:15 PM
| | Motorized Bicycle Apprentice | | Join Date: Jun 2008
| | Help!!! I Need A Part!! Dag Nabbit. Wouldn't ya know it? I just bought one of those 80cc two stroke jobbies, got it all set up, and on the first attempt to start that sumbitch the clutch plate retainer nut stripped off. OMG. Does anyone here have a spare?, or know of a place to get that darned thing? Am I really up against it now, or is there light at the end of this tunnel?
RED
06-23-2008, 05:46 PM
|  | HS Math Teacher | | Join Date: Jun 2008 Location: arkansas
| | Re: Help!!! I Need A Part!! i have no idea what you are talking about, can you post a picture?
my clutch plate broke a bit in the spot where the steel retaining pin is. I used a bit of JB Weld on it and now it stays in. |
06-23-2008, 07:44 PM
| | Re: Help!!! I Need A Part!! Ok,this star nut, is actually supposed to be threaded inside, and it holds the clutch pack tighly inside the primary case |
06-23-2008, 08:53 PM
| | Re: Help!!! I Need A Part!! ah yes i know where that came from...DON'T USE JBWELD ON THAT!! i do not have a replacement.. . you may have to buy the whole assembly...but i have no idea |
06-23-2008, 09:00 PM
| | Re: Help!!! I Need A Part!! do you know who has the whole assy? getting parts for these motors seems to be ridiculously tough |
06-23-2008, 09:02 PM
| | Re: Help!!! I Need A Part!! weld it up to build up the striped threaded area then drill and use the correct metric tap.or
check with one of the vender's here there's US and Canada dealers.
06-23-2008, 09:45 PM
| | Re: Help!!! I Need A Part!! Thanks, but welding is not an option right now. don't have the gear. will try the vendor section.
outlook grey |
06-24-2008, 06:28 AM
| | Re: Help!!! I Need A Part!! Contact your seller first, then start contacting everybody else. Look for burnt up or warranty return engines for parts such as these.
06-24-2008, 07:34 AM
| | Re: Help!!! I Need A Part!! I am contacting the seller. It seems a shame to have to purchase another motor just to get a nut. especially since I have gotten no use of my new motor yet. wonder if I can find a machine shop to make me another.?.?.? |
06-24-2008, 01:54 PM
| | Re: Help!!! I Need A Part!! The seller should replace the defective part....how did you strip it anyway?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:30 PM. | | | Sponsors
