| | | Swap And Shop Use this forum to buy, sell or trade your motorized bicycle items. | Hardware Kits for Chinese 2 Stroke Discussion at Motorized Bicycle Engine Kit Forum in the Swap And Shop forum. Finally it is here. The engine hardware kit from SBP. Replaces all hardware on the engine except the cylinder stud ...  | |
12-11-2008, 10:44 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Bellingham, WA
| | Hardware Kits for Chinese 2 Stroke Finally it is here. The engine hardware kit from SBP. Replaces all hardware on the engine except the cylinder stud hardware and the 2 engine case bolts at the base of the cylinder. All are Grade 5 or better. $9.95 Sick Bike Parts
12-11-2008, 10:50 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Hardware Kits for Chinese 2 Stroke Nice job guys.
I'm curious, how many of these pieces does the hardware that comes with the shifter kit replace? |
12-11-2008, 10:52 PM
| | Re: Hardware Kits for Chinese 2 Stroke The Shift Kit will replace the rear motor mount studs, the 3 sprocket cover bolts and 3 of the 5 clutch cover bolts. |
12-12-2008, 02:04 PM
| | Motorized Bicycle Senior Member | | Join Date: Oct 2008 Location: Grunthal, Manitoba, Canada
| | Re: Hardware Kits for Chinese 2 Stroke I have a suggestion. On many bikes the mounting studs that come with the engine arent long enough. Perhaps you could make the engine mounting studs longer. |
12-12-2008, 03:24 PM
| | Re: Hardware Kits for Chinese 2 Stroke Front or rear motor mount studs? |
12-16-2008, 11:15 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2008 Location: Aus
| | Re: Hardware Kits for Chinese 2 Stroke WOW!!!!!!!!!!!!!!!!!!!!!
TOTALLY AMAZING DEAL. I GOT ALL THAT HARDWARE FOR UNDER $10.
Once again, a friggen homerun from the SBP guys. The stuff is tight. You guys are THE MAN. I would say if you have a HT, just buy this ****. You will be all set up.   |
12-17-2008, 05:36 PM
| | Re: Hardware Kits for Chinese 2 Stroke Quote:
Originally Posted by Ghost0 Front or rear motor mount studs? | Most of the time its front. |
12-17-2008, 05:46 PM
| | Re: Hardware Kits for Chinese 2 Stroke I hear that but let me add this comment. In my opinion, if you need longer front studs this is typically due to an over sized or elongated front tube. If this is the case I would recommend that a different front mount is fabricated anyway. SBP is working on one and it should be available soon. |
12-18-2008, 09:57 AM
| | Re: Hardware Kits for Chinese 2 Stroke Nice. Will it have built in vibration reduction? Sick Bike Parts is doing a good job of making these little HTs way better. |
12-18-2008, 11:01 AM
| | Re: Hardware Kits for Chinese 2 Stroke It will but not using any sort of rubber or plastic, more of a leaf spring type of vibration isolation. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:29 PM. | | | Sponsors
